When is it safe to wax a new car?
Originally Posted by superz
I think you mean Polishing, not buffing with rubbing compound. Every time you use a polish or rubbing compound you are removing paint, very bad in the long run.
Originally Posted by twan
your MR was built in august, your fine, wax away
phew, i washed my car this weekend with dishsoap cuz i ran out of carwash, i always thought it was ok...but that makes sense about using it before you wax. after the wash i laid down a nice layer of Meguiar's NXT wax
How soon can I wax a new car?
A new car that has a factory paint job can be waxed the moment it is rolled out of the plant. Cars that have factory paint jobs are cured at much higher temperatures, because the car goes through the paint booth without the rubber, plastic, and cloth components. This means the paint is cured by the time the car is completed. After-market paint finishes, however, are cured at a much lower temperature to ensure the booth doesn't melt non-metal components. In this case, allow for a 2-3 month curing process before your first wax application.
http://www.meguiars.com.au/Get_Schooled37.htm
