need help taking off wing
Old Jul 8, 2005 | 12:42 PM
bluebanana23's Avatar
Is there only 4 screws to unscrew? It still won't budge after taken all 4 off. Is there any trick to it?
Old Jul 8, 2005 | 01:00 PM
haze1995's Avatar
There is some double sided tape as well as 2 clips in the wing. You have to use some muscle. The tape should pop off with some effort. Hope this helps.
Old Jul 9, 2005 | 12:22 PM
xepyt's Avatar
on another note, what size are the bolts?
Old Jul 9, 2005 | 12:26 PM
DCSilvrEvo's Avatar
They are 10mm
Yea after the four screws just lift each said with a lot of muscle and it will come right off. NO CLips!
Old Jul 9, 2005 | 12:53 PM
F&I-EVO's Avatar
Used Fishing Line To Cut The Glue
Old Jul 9, 2005 | 12:57 PM
thanks guys
Old Jul 9, 2005 | 02:35 PM
chiquita's Avatar
assuming since you posted this thread in the evo forum, that you have an evo. why are you taking off your wing? if you don't like the big wing look, I am selling my stock spoiler off of my RA for a reasonable price. if you just don't want that big wing look, and if you want something nice and not aggressive looking then PM me.
Old Jul 9, 2005 | 02:43 PM
8urv8's Avatar
There are only the four bolts holding it on. Just pull with a steady amount of force until you feel the adhesive start to give. I pulled from front to back on both sides equally. Just be careful not to scratch your paint.
Old Jul 11, 2005 | 10:09 PM
ebbeast2005's Avatar
how is it when you put it back on? Any diffrent i want to check out the look but im sure i will go back to wing.
Old Jul 11, 2005 | 10:20 PM
they sell 2x tape at autozone for 3 bucks
Old Jul 11, 2005 | 10:29 PM
SJCoruja's Avatar
Definitely use the fishing line..makes it a lot easier to remove. I took mine off and will be selling it off soon.
Old Jul 12, 2005 | 08:20 AM
BensLancer's Avatar
you trying to get rid of your wing? I might be interested if you are!!!!!!!!!
Old Jul 12, 2005 | 02:18 PM
chiquita's Avatar
btw.. will a 04 ralliart spoiler fit on a evo 8? I mean, there would be adjusments but, where there be a lot of adjustments for putting a ralliart spoiler on a evo? it, does it just not fit at all??
