Carbon fiber bumper ducts installed!!
From: driving the 10 second beast in ohio or running lightmods.net
group buy:
https://www.evolutionm.net/forums/sh...d.php?t=163015
Guys these are for real! Top quality and fit. special thanks go out to Matt at Slickmotorsports for helping me install them... worked out great.... we used a rear low profile black headed screw ....first i drilled the holes in the carbon ducts...most were already marked on the ducts (took about 10 minutes). ONce that was done we placed them up there where they needed to be (check, check and recheck). Then we drilled a couple smaller pilot holes into the actual bumper . Once that was done we screwed it in....simple as that...
Notice in this picture i drilled the holes (then just set it on the bumper) so you could see how the spacing goes....
with stock oil cooler guide back on the rear of the pass. side
drivers side with intake duct connected!
ok more pics up close and others::
Originally Posted by h22gordo
Looks great, although I wish they made it in a 1x1 carbon weave so it would match your Do-Luck lip, and the OEM rear spoiler!
