Work Emotion Cr Kai ?
Old Nov 1, 2005 | 06:50 AM
EvoEmperor4G63's Avatar
I was thinking about buying these wheels....what do u guys think?
http://www.work-wheels.co.jp/wheels/...1p-2/view3.jpg
does anyone have any pictures with the work emotion cr kai wheels on there evo?
i have a apex silver evo...i dont know if the bronze would like good or not? ill probably go with gunmetal
what do you think?
Old Nov 1, 2005 | 06:54 AM
lookEVO's Avatar
those are basically like the IX wheels.
Old Nov 1, 2005 | 07:11 AM
Mike@Forge's Avatar
Old Nov 1, 2005 | 07:50 AM
voidhawk's Avatar
Old Nov 1, 2005 | 07:52 AM
Derek888's Avatar
VoidHawk
Whats the offset and size on those rims? they look really nice...havent seen any with that kind of offset
Old Nov 1, 2005 | 08:21 AM
MitsuJDM's Avatar
The 9 wheels have more spokes and are BBS
Old Nov 1, 2005 | 08:47 AM
voidhawk's Avatar
Originally Posted by Derek888
VoidHawk
These are 18x9.5 +38 with 275/35/18 tires. Be warned though that they are not direct bolt on, I had to do a lot of work to make things fit. The fenders are rolled, and I'm using stiffer bushings to reduce deflections.
In the pics above, I'm also using 25mm spacers in the front (needed to clear the brembos), which was great for inducing oversteer (wider front track) but caused some rubbing on the fender lining at full steering deflection. I have since reduced that to 15 mm together with upgraded brake calipers to clear the spokes, very happy with the setup now.
Old Nov 1, 2005 | 09:12 AM
Mike@Forge's Avatar
Mine are 18x8.5 with a +30 offset.
I'm using a 245/40/18 Falken Azenis RT-615 tire which comes really close to rubbing on the rear fender lip, but doesn't rub at all (within 2-3 mm though). Most people use a 234/40/18 tire on this size wheel though just to be safe.
Old Nov 1, 2005 | 10:14 AM
forum04pl's Avatar
here is mine 18x8.5 with a 245/40/18
check out the link in my sig for more pictures
Old Nov 1, 2005 | 12:34 PM
flabarm's Avatar
One of my favorite wheels. YOu should definitely get them if you can afford em. I wanted to get those wheels for my rsx, but never got around to it.
Old Nov 1, 2005 | 01:10 PM
voidhawk's Avatar
Not to hi-jack your thread, but since all the owners are in here - have any of you guys found center caps that fit on these?
Old Nov 1, 2005 | 02:52 PM
expl0d's Avatar
http://my.prostreetonline.com/member/evo%20jay/
Old Nov 1, 2005 | 04:49 PM
bestthereis27's Avatar
Voidhawk are those the gun metal, or bronze finish? I can't really tell, my lcd screen is kinda old
Old Nov 1, 2005 | 04:57 PM
voidhawk's Avatar
gun metal
Old Nov 1, 2005 | 05:12 PM
BMan's Avatar
It's white, but you get the idea. Bronze 17x8.
