Climate control issue...
Old Nov 28, 2005 | 06:48 AM
SuperHatch's Avatar
Originally Posted by MIevo8MR
Usually what causes this is some miscommunication between the control head and the AC clutch control which I believe is tied into your PCM. Might be a bad relay, might be a bad control head, or might be something wrong with the PCM communication.
Best bet is to try to find someone with a working control head, plug his in and see if it does the same thing.
Good idea... I'll try to give this a shot. I mean, there are plenty of people parting out lancers all the time so I can just pick one up, I just don't want to spend the money if A: it's not the problem, or B: There's a simple fix.
Thanks for your help guys...
SuperHatch's Avatar
Originally Posted by mrbkkt1
any liquid? armor all etc, get near the switches???you'd be surprised what i have found in switches sometimes. best thing to do is to find another lancer in the area and do a quick swap to test the switch. also check behind glove box to see if pushing the switch actually switches from recirc to fresh air.
Might have gotten some Vinylex in there, but I doubt it. I'll check though, thanks.
Old Nov 28, 2005 | 07:24 AM
JoizeeX's Avatar
hey, i started to have similar problem just recently. it's not stuck ALL the time, but once in a while the AC LED stays on eventhough the temp knob is in the max RED and selector knob is on lower + middle vents. after a lil while it turns off. hard to duplicate.
Old Nov 28, 2005 | 07:29 AM
SuperHatch's Avatar
Weird... I'm going to check into this more, it just annoys me. I like things to work the way they're supposed to.
Old Nov 28, 2005 | 08:31 AM
Ichiban's Avatar
Originally Posted by SuperHatch
You should try reading my post chief, I said it's stuck on in every temperature knob position. I'm not as stupid as you'd like me to be.
No insult was intended. You're right, I just misread.
It may have gotten stuck in this mode. When you removed the controls and looked behind, there wasn't anything broken? wire pinched? I know you stated everything looked ok, just confirming.
Did you try resetting the computer? Not sure if it's related, but worth a shot.
Old Nov 28, 2005 | 10:37 AM
SuperHatch's Avatar
Well that was the kind of snide comment I would have made, so I thought it was
I'll look again but I didn't see anything. But then again, when it's turned on MAX A/C the recirc function is also forced on, so maybe that is the problem. I'll check again when I get home from work.
- Steve
Old Nov 28, 2005 | 12:47 PM
JoizeeX's Avatar
- Steve
as far as i remember the recirc in that AC setting has always turned on. i believe that's how it's supposed to be: u don't want to suck in warm humid outside air. (dunno if u were unsure about that, so letting u know just in case)
Old Nov 28, 2005 | 12:50 PM
SuperHatch's Avatar
Yeah, I knew it was supposed to do that.... we'll see what's what later tonight.
- Steve
Old Jan 23, 2007 | 11:53 PM
Bigl4201's Avatar
back from the dead bump. i am having the same issues as the OP. can anyone explain ? thanks
