Climate control issue...
Old Nov 27, 2005 | 10:48 AM
SuperHatch's Avatar
Here's the deal...
I have a problem with my climate controls, just started happening yesterday, and I'm not sure what would cause this.
Whenever the fan is on, at any speed, the AC is on, the compressor kicks in, and the LED AC light is on. Hitting the AC button does nothing, changing the temperature does nothing, and changing the vent position does nothing.
The vents are permanently on "recirculate" unless I go to a defroster setting. Pushing the RECIRC button, once again, does nothing.
The whole AC being stuck on this wouldn't be bad, if it wasn't WINTER.
I have no idea what would have caused this, I checked the connections on the back of the climate control and all seems fine. Any suggestions? Weird fuse I might not know about?
Thanks,
- Steve
Old Nov 27, 2005 | 11:05 AM
KazzEvo8's Avatar
I really don't know - but realize this is about the compressor, not necessarily cooling. Technically, all it's doing is removing moisture from the air. You can put the temp wherever you want.
My guess is a sensor behind the dash as to knob position. Either the A/C switch is broken/hosed or the sensor for the dial being turned all the way counterclockwise is broken/hosed.
Good luck, curious m'self ...
Old Nov 27, 2005 | 11:12 AM
Ichiban's Avatar
Move the temperature control knob off the "max a/c" setting
Old Nov 27, 2005 | 11:18 AM
andenbre's Avatar
when you have it in defrost mode the compressor runs also
Old Nov 27, 2005 | 11:22 AM
silverlining's Avatar
Why is your A/C issue in show and shine?
Old Nov 27, 2005 | 11:25 AM
SuperHatch's Avatar
You should try reading my post chief, I said it's stuck on in every temperature knob position. I'm not as stupid as you'd like me to be.
Old Nov 27, 2005 | 11:26 AM
SuperHatch's Avatar
I know, but it won't go off no matter what position the vent setting is on.
Old Nov 27, 2005 | 11:28 AM
SuperHatch's Avatar
Well it definately isn't an "engine turbo drivetrain" issue. And if you read the description of "show and shine" it says this section is for stereo and electrical discussion. This is electrical, hence why I posted here. Last time I checked there isn't a "Evo Electrical Gremlin Forum"
Old Nov 27, 2005 | 11:31 AM
SuperHatch's Avatar
I realize this, and the heat still works fine once the car is warmed up. But this still is a pain in the a$$ for two reasons.
When the car is cold in the morning, it takes that much longer for me to get heat, since it doens't only have to be warm, but warm enough to warm the outside temp and the AC cooled temp.
Running the AC compressor all the time will put added wear on the compressor and decrease fuel effiency slightly.
Agreed, I just wanted to see if anyone else had experienced this and I was maybe missing something. If not, I'll go buy a new climate control.
- steve
Old Nov 27, 2005 | 11:33 AM
AaronOZ's Avatar
This is because you are on "Defrosting" front window-shield position
Old Nov 27, 2005 | 11:49 AM
SuperHatch's Avatar
Do any of you people READ?!?!?!?!
This happens NO MATTER WHAT POITION ANY SWITCH IS ON!!!!
Old Nov 28, 2005 | 05:15 AM
SuperHatch's Avatar
ttt
Old Nov 28, 2005 | 05:23 AM
mrbkkt1's Avatar
any liquid? armor all etc, get near the switches???you'd be surprised what i have found in switches sometimes. best thing to do is to find another lancer in the area and do a quick swap to test the switch. also check behind glove box to see if pushing the switch actually switches from recirc to fresh air.
Old Nov 28, 2005 | 05:27 AM
MIevo8MR's Avatar
Usually what causes this is some miscommunication between the control head and the AC clutch control which I believe is tied into your PCM. Might be a bad relay, might be a bad control head, or might be something wrong with the PCM communication.
Best bet is to try to find someone with a working control head, plug his in and see if it does the same thing.
Old Nov 28, 2005 | 06:46 AM
EvoVIII_SFL's Avatar
rofl. owned.
