MB Competition Wheels 17X9
Old Mar 5, 2006 | 11:25 AM
jid2's Avatar
I know I had lots of questions about these wheels, and not alot of people are running them. I bought them on "faith" that they would fit.
They are 17X9 with 27 offset, I'm running 255/40/17 RA1's on them. They have no problems in the front. They dont rub turning lock to lock.
The rears do rub a little on the rear fender lips under hard cornering load, and will require some minor work. But I was aware of that going into this.
The wheels are available from Discount Tire, I got mine for a deal I can't post but it was under $135 a wheel.
These are a great, cheap option for race wheels. Weight is about the same as the stock wheels.
Old Mar 5, 2006 | 11:54 AM
EVOLUTIONIZE's Avatar
Will rims with a 32-35 offset take care of the rubbing problem? Or that wont make any difference in the rear!!!?
The RA-1's look like they fold a bit to the sides, will a different tire maybe take care of the rubbing problem? Talking about same size different brand. 255/40/17
How low are ur springs?
Old Mar 5, 2006 | 04:43 PM
jid2's Avatar
I'm on Hotckis springs.
No 255/40/17 would fit without rubbing on these wheels. As far as 32-35 offset working, It varies wheels to wheel. But that would be less of a problem then the 27's. But 27 makes a great wide stance. And the trimming/rolling of the fenders is not to bad.
Old Mar 5, 2006 | 05:43 PM
scott88vr6's Avatar
EVOLUTIONIZE This wheel is only available in 27mm offsets
Old Mar 5, 2006 | 06:39 PM
cyberevo8's Avatar
nice were can i get it??!?
Old Mar 5, 2006 | 09:43 PM
jid2's Avatar
Are you serious? Read the first post again. Discount Tire.
Old Mar 5, 2006 | 10:47 PM
jdm_evo's Avatar
i think these wheels look good. correct me if i am wrong, but i believe MB is just a distributor for these wheels because the maker of the wheels is A-TECH which is out of Japan. you can find these wheels in the HYPER REV mags from Japan.
anyways wheels look dope!
Old Mar 6, 2006 | 07:54 AM
jid2's Avatar
That's correct. The wheels are made by A-Tech, and have a different name in Japan. Discount tire has their own in house brand which is called MB Wheels. They use a bunch of different companies to create that MB Wheels line, and the Motorsports group is made by A-Tech.
They also have a wheel called the Weapon which is a 7 spoke Gramlights 57f knock-off. Same size and offset as my wheels.
S2Kstephen
Apr 2, 2006 07:45 PM
1NastyEvo
For Sale - Wheels / Tires
14
Feb 18, 2006 12:25 PM
JSYEVO
Jan 30, 2006 06:13 PM
eve-slow
Jan 9, 2006 01:02 AM
stockEVO_8
Dec 18, 2005 11:28 PM
