--cj9a--
Old Mar 20, 2006 | 05:20 PM
  #61
AznX TL's Avatar
Originally Posted by Bexa20
I was thinking about doing something like your project but I heard that you have to get the floor in order to fit the AWD sysytem???
and part of the trunk....and you'll have to move the fuel tank
Old Mar 20, 2006 | 05:28 PM
  #62
sireel's Avatar
WOW! I never seen anyone get so much props and no bad press! Great job on the build!
Old Mar 20, 2006 | 05:52 PM
  #63
AdamJ39's Avatar
you do not need the floor, you do have 2 options with the rear pan...1 to supply an Evo pan...or construct your own...you do not need to move the fuel tank, only need an Evo4-6 tank since the fuel door is located on the right side of the car...but you do need to change a structural member for the front Diff Carrier mounts which also incorporates the Rear Tank mounts...the car from the rear seat forward is the same between a 2 and 4 door also cept the the carrier mounts for the driveshaft which there are 2 in a 4 door and one in a 2 door...and thus i have a 2 Piece driveshave VS a 3 piece...but as Murry at TAD (a rallyshop near chicago) told me...they turn all there driveshafts into 2 piece shafts anyway for rally so no loss there...i could go on and on and on about differnces and such but i'll prolly burn up my keyboard..
-Adam
Old Mar 20, 2006 | 07:01 PM
  #64
static63's Avatar
Good job on the car man!
Old Mar 20, 2006 | 07:07 PM
  #65
EVOKing8's Avatar
sick car man wow looks so hot
Old Mar 20, 2006 | 07:24 PM
  #66
Oscypek1007's Avatar
amazing freakin beatiful car... o and if your selling ring me up
Old Mar 20, 2006 | 07:27 PM
  #67
Bexa20's Avatar
What I was thinking of doing is getting the Mirage and the EVO8 after the accident (since we can get most if not all the parts) and swaping everything into the Mirage. How much modifications had to be done to fit the engine and transmission, also which suspension is in there?? Is it from the 8??
Old Mar 21, 2006 | 03:57 AM
  #68
donmeca2020's Avatar
OW nicest 2 door i ever seen.
Old Mar 21, 2006 | 05:36 AM
  #69
Hittman's Avatar
Were you the guy with the primed Mirage a couple years back when IX had its BBQ?
Old Mar 21, 2006 | 06:21 AM
  #70
evo 8 ya's Avatar
That thing looks great with the GG paint. It's going to be a awesome ride to the beach for the OC car show this year.
Old Mar 21, 2006 | 06:47 AM
  #71
AutobonEvo's Avatar
wow wicked nice!
Old Mar 21, 2006 | 02:32 PM
  #72
AdamJ39's Avatar
Evo 5-9 rear's are all the same with the exception that on Evo6 the revised all the control arms by making them out of Aluminum vs Steel....
and the front is Evo5, with the Extended Aluminum Lower control arms Knuckles and Axles...similar and allmost identical in size to the Evo8 arms where the Hubs have enlarged splines and the lower ball joint on the knuckles is also larger...also the rear mount on the Evo8 Ft. Lower arms is a Spherical Ball Joint Vs Rubber on the Evo4-6....
one thing you learn allmost imediatly is that Mitsu hasnt changed much at all since Evo5...very minor changes...but overall everything is set up the same exact way...
Hittman-- No that is not my car...it was black sealer at Evo Vs STI last summer in englishtown if anyone remembers that...
Who was asking if i'd be selling it...not that i am...but i am curious to what anyone thinks its worth...
-Adam
Old Mar 21, 2006 | 03:21 PM
  #73
Karash's Avatar
Have to admit, thats pretty hawt. Nice car!
Old Mar 21, 2006 | 09:44 PM
  #74
Boost20psi's Avatar
wowww, very nice
Old Mar 28, 2006 | 04:04 PM
  #75
Bexa20's Avatar
Would that be you AdamJ39
