Anodized Buschur FMIC
if it shows its old color from getting banged up by rocks out comes the sharpie
... Well seriously I would be pretty mad if it did and it probably will get banged up I am sure of that
Originally Posted by antilag_200
thanks
as far as performance goes... whether it is an increase or a decrease I can't tell because I don't know but I doubt it hinders performance... it just gets rid of the "hey look at me I am big front mount come race me please" That is what I wanted to get rid off because I was so tired of dealing with the stupid kids in this town that think they have to race me to prove something.
I got it anodized versus painting because firstly in my opinion I think it will hold up better againtst rocks than paint would... also I wasn't familiar with "heat transfer paint" researched a little on anodizing and seeing a few pieces of aluminum anodized really sparked my interested... as it made the parts look almost billet.. Plus it has bling points with ricers when you tell them that your IC was dipped in a vat of sulphuric acid
(just some comic relief)
plus for 55 bucks I didn't think it was a big deal.
(just some comic relief)plus for 55 bucks I didn't think it was a big deal.
Hey J ,
thanks for dealing with all my BS over the phone when you guys were waiting on endtanks... INSTALL took me less than an hour ... piece of cake..
I paid 55 bucks to get it anodized.. as I get some discounts from the a place here in jackson... I am sure any anodizer in your area would do it for less than 100 bucks... Most expensive part was the caps that he had to buy, because basically he had to fill the IC full or water first so that it would SINK in his tanks
he kept on telling me damn "that cooler there sure do hold a lot of water" hahahaha
he kept on telling me damn "that cooler there sure do hold a lot of water" hahahahaLet me know if you need anything.
Jarrod
Buschur Racing Inc.
If you used heat transfer paint (or any paint) you would need to mist it on. This has been covered on threads before about 'don't paint your intercooler.. blah blah..' but I believe that if you 'misted' it to a black tint that you would slightly change the heat transfer properties of aluminum.
Heat transfer paint
Pros
Painting can be easy (if you are good)
It can be cost effective (as an engineer.. nothing is 'cheap'
It can be touched up in the future and you only need to (i would only recommend 'misting' one side
Cons
You are covering the intercooler and may slightly affect it.. If done with care this should be very minimal
The paint may chip/peel from age and rocks
Salt may affect the paint
If you are not good at painting the layers may look 'blotchy'
Anodizing the aluminum is a completely different process it changes the aluminum surface to its oxide. It is a procedure in which the aluminum is electrified in a bath and a chemical reaction takes place. Anodizing can be in many colors and mulitple colors on the same part.
Pros
Very strong (it actually hardens the surface of the aluminum)
More abrasive resistant and holds up better to being 'beatin up' by the road debris
It will not peel like paint
Long lasting
It is thin (on the order of 0.002")
Cons
It can be done at home - but may be expesive to start the first time, so for the diy'er it means you have to take it somewhere and it might be expensive cost... or should i say 'cost may vary dependant on your area and how much of a ***** the guy is who you want to have this done by' - thats better
Aside from that.. I can't think of cons.. It can be changed later.. but is difficult and deemed to only be done by a 'professional'
Anodizing is the way to go if you want it permanent and you want a good finish and to increase the hardness of the AL.
Painting is the way to go if you want a quick job (make it look good) and you may consider changing it later. You can also do it yourself
Sorry for the long post.. I hope it sheds some light on the situation.
-Wes
Heat transfer paint
Pros
)It can be touched up in the future and you only need to (i would only recommend 'misting' one side
Cons
Pros
Long lasting
Cons
-Wes
