Anodized Buschur FMIC
Originally Posted by Fluid1
Where's your proof, smart guy? Dyno sheet? Temperature tests?
I have a finance degree, so you're correct about engineering.
and believe me a dyno isn't teh best way to measure performance on such a detailed level unless it;s in a completely controleld enviroment (ambient air temp, humidity, barometric pressure) the correction factors on Dyno's will change dramatically depending on where the sensors are placed.
i knew of a shop placed the sensors in the Water heater closet but ran the cars in an open bay, when the computer "corrected" the numbers to STD it would alwyas be higher. becaue it though it was 90+ degrees and humid no matter what.
antilag_200
Dec 4, 2012 09:22 AM
