Autometer Boost Gauge with Steering Column Pod - Pics
Old Jun 20, 2007 | 02:01 PM
vortech_g35's Avatar
Nice!!!!
Old Jun 20, 2007 | 06:41 PM
GroundChuck's Avatar
Thanks for the kind words (all). It's been in over a year now and works great. I know others don't care for Autometer too much but it has been working for me nicely.
The only real complaint I have (which is a very minor one) is that the condom that you put on the bulb (for red backlighting color) seems to fade after about 5 months or so. So now my backlight color is sort of light red. Although 5 months of driving for me is about 9000 miles and I also have the thing wired so it's on all the time (when the car is on of course). It's not tied to the dimmer so it only comes on when the lights are on. If I did that it would cut down on the bulb usage a ton (for me at least).
Originally Posted by urslo4n8
VERY NICE clean install. Thats what i like to see. Not some butchered **** job. Im thinking about getting that setup.
Old Jun 20, 2007 | 06:57 PM
Redline-Z's Avatar
Veteran: Air Force
If you splice it to the green/yellow wire under the fuse block(White harness) it will only come on when you turn your lights on. I would recommend that you do not use the dimmer.
badboybr09's Avatar
the mount looks just like mine. good job.
Old Jun 20, 2007 | 09:02 PM
gregfromblur's Avatar
haha i have my defi right there. you can still see everything perfectly fine too... except that pesky check engine light.
Old Jun 20, 2007 | 11:21 PM
Kapoosh1's Avatar
looks great! I just did an identical install on my evo recently, i really like it so far.
Old Jun 21, 2007 | 05:23 PM
Good tip. Thanks! I knew there was a way to have it only come on with the lights, but I've honestly been too lazy to search for it .
Kap, Greg, and Br09,
Thanks for the compliments! (Feel free to through up pics of your too if you like).
Old Jun 21, 2007 | 05:29 PM
Redline-Z's Avatar
Veteran: Air Force
I believe Evomoto has pics of it under one of their install threads. Just use the pics and it is easy. I searched around and the dimmer is a real low current and your gauges can fry it out cutting out your headlights and stuff.
Edit: Just verified the Green/Yellow wire is for the parking lights.
Old Jun 21, 2007 | 07:26 PM
Peteypab2133's Avatar
best of luck with that gauge.. mine reads about 5 psi off at high boost... (this is my second gauge BTW) first was off too.
Clean looking install
Old Jun 22, 2007 | 07:40 AM
V.8MR's Avatar
You block the CEL to. Awsome!!!
Old Jun 22, 2007 | 09:18 AM
I have always been curious about the accuracy of the gauge (based on comments from others). How did you verify that yours was 5 psi off?
Thanks!
Originally Posted by Peteypab2133
best of luck with that gauge.. mine reads about 5 psi off at high boost...(this is my second gauge BTW) first was off too.
Old Jun 22, 2007 | 09:59 AM
Kapoosh1's Avatar
you can just buy a red bulb offline somewhere and that will solve your problem for good
Old Jun 22, 2007 | 10:09 AM
Redline-Z's Avatar
Veteran: Air Force
I bought my red leds from 42draftdesigns and they match perfect! look into it, mine were for Stewart Warner's
Old Jul 6, 2007 | 09:30 AM
Excellent find on the LEDs. I ordered a regular and high output red today (I wasn't sure which one would be best). I post some pics when I get them.
Old Jul 6, 2007 | 09:35 AM
Gary 805's Avatar
MOTHA FA#$@ER You got cruise control?
