Interior panel removal for stereo install
Old Apr 30, 2006 | 03:27 PM
Positron's Avatar
I tried searching for threads about removing the interior panels for a stereo install but had no luck.
What I'm trying to do is finding out the correct way to remove the panels on the driverside. So I can have a battery wire running from engine battery to the trunk.
Old Apr 30, 2006 | 11:31 PM
NocturnalEVO's Avatar
well everything pretty much just pulls right out. You just gotta put some force into it, but not brute force. Just pull, one end at a time, and everything will pop right out. As for the bottom of the B-pillar cover, its' basically just "wrapped" around the b-pillar, so you just pull it off from one side, and then it'll j/come off by itself.
For the rear seat, if you look in the bottom of the seat, there is like a pull switch thingy, if you pull it out ward, the seat will come loose (bottom half), and once you're there, you can run the wires straight into the trunk along w/the other wires that are already there (you'll see them once u get the panels/seats popped out). THen you will need to take out the trunk liner in the back side so that you can get the wires.
I hope that helps
