What do you guys think about these rims,,
From: driving the 10 second beast in ohio or running lightmods.net
btw i would also run a small rear spacer maybe (5-10mm) to bring the wheels out more...i am guessing those are some 35-38mm or higher offset. Then on the front prolly a 15-18mm offset to bring them close to the edge and like i said prolly either a stock size tire or 245 40 17
Ya they came off of my car I parted out!! I called it the EVO FUND..
anyway I want to put these rim on!! What will I gain with lighter rims MPR or faster 1/4 times>> ..So I'll prob order longer studs and spacers in the near months.....Right now I like the look of the the stockers
Originally Posted by evodave
whats the offset on those wheels? start there....don't rule them out if you want a simple (hopefully very cheap upgrade) start by finding out the offset then figuring out what size spacers you need to run and swap your wheel studs for some longer units (very easy) especially now that ARP finally has the kit out for our cars. When i did mine forever ago i had to use mustang ones and bore everything out to make them fit. Then get some larger tires ..... i would say a 245 40 17 or 255 40 17. It is a lot of work but IF you are getting the wheels for a stupid good price then its worth it.
