Seibon Hood Questions w/pics...
So my Seibon hood came today and I'm very pleased so far. There are no visual blemishes and the weave looks great.
Are there any tips as far as mounting? Do I need to know anything before I start trying to mount it up? I'm trying to get the fit as close as possible.
What about under the hood? Do you just leave the vent that's in there or do you try and swap out the stock vent & underhood heatshield?
evodan2004 - what did you end up doing and do you have any shots of of the underhood?
It does not mount up like stock and will require some customization. I just dropped it off at the dealership's body shop and they're going to do it for me - so I'll just keep my fingers crossed that it comes out okay.
just put the stock mesh on it. looks better and matches. I had a vis, and all i had to do was drill two different holes so that the stock mesh would fit. by the way my hood fit just like my stock hood. perfect!!, and try to put on the heat sheild, because after some hot days and the motor just roasting under the hood, some clear coat started to crack.
looks good and show some pic of your ride
here are some of unde the hood. there the best i got. i can take more for you but this is the idea. as you may not know my hood was keyed a week after that pic. i MAY sell that vent part. so if you **** up let me know. pm me if you want my number and il help you out over the phone on how i did it.
Originally Posted by ~EVILEVO~
What happened to your car doug? Joe told me its in the shop?
Here's a shot of it several weeks ago over at the shop: http://www.sp00lin.com/Evocrash.jpg
Evodan - Sorry to hear that some a-hole keyed your car. That totally sucks. Where was the car when it happened and where'd they scratch it up? Can you make an Comprehensive claim against your policy?
BACK ON TOPIC - I plan on trying to modify the hood so that the stock heat shield and vent are attached somehow. I may also try adding some heat tape and some kind of spray that is supposed to protect it from heat.
Originally Posted by SP00LIN
I got rear ended on the I17 and pushed into a blazer with a trailer hitch.
It f'd my car pretty bad.
it is easy to put the vent in bro. i hope the pic's help. like i said i may sell this one. but you no my number if you need a hand. member cut 1 time measure 2 times. take your time. it will look great when your done.
