Is this gap between the bumper and head light normal?
Old Sep 11, 2006 | 03:29 PM
tirbolag9's Avatar
yeh, my driver side bumper is like that but not as wide of a gap.
Old Sep 11, 2006 | 03:33 PM
E_vo_lu_tion's Avatar
same here.....
Old Sep 11, 2006 | 04:32 PM
kee's Avatar
kee
mines looks like that too.. mine is a brand new 2005
Old Sep 11, 2006 | 07:42 PM
era-teknic.com's Avatar
you should adjust your headlight. do the bottom adjustment first to bring the bottom of the light in more then adjust the top to bring the top in more to even it out and so your lights face properly.
Old Sep 12, 2006 | 07:35 AM
porque's Avatar
I have HID's which are adjusted via a switch in the cabin, and since I have Tanabe GF210's installed I needed to point the lights as high as they would go.
Old Sep 12, 2006 | 08:51 AM
Sap12687's Avatar
Mine looks the same. Kinda bugs me but you can only tell when you're up right next to it.
Old Sep 12, 2006 | 08:59 AM
DRFTKNGG's Avatar
If you take the bumper back off you will see two metal tabs under the headlights....its metal tab, body colored, sticks out a little. Try bending this upwards so that it supports the bumper when it rests on top of this little tab piece.
Also check to see if your pipes from intercooler and that they are not resting on the bumper causing the bumper to hang.
If this doesnt work, I have used some race wire tie to add additional support.
Old Sep 12, 2006 | 09:44 AM
vennom's Avatar
Old Sep 12, 2006 | 09:45 AM
vennom's Avatar
whoops meant to say +1
Old Sep 12, 2006 | 11:15 AM
Kee1pride's Avatar
mines the same way. no big deal. always has been that way sincei bought it with 8 miles. oh well
Old Sep 12, 2006 | 11:25 AM
RRRS's Avatar
i think those tabs you speak of are there to hold up the crash bar while you bolt it down, i will check it out again tonight. also, there are tabs, but they're on the bumper cover, under each headlight. somehow, they aren't clamping down like they should, possibly those foam blocks shifted or something.
i say the gap is NOT normal, and it can be fixed. mine was not like that before.
Old Sep 12, 2006 | 11:43 AM
EVIL_EVO_VIII's Avatar
mine too, on my passenger side ,the little with tips that go to the headlight that are in the bumper dont wana lock in place
Old Sep 12, 2006 | 11:46 AM
justchil's Avatar
Mine looks like that after removing the crash bar.
Old Sep 12, 2006 | 12:04 PM
t-blizzard's Avatar
its fine
Old Apr 10, 2007 | 03:35 PM
sonicnofadz's Avatar
I have an even worse gap on my passenger side. I bought another OEM bumper off a different Evo (came with Varis lip, canards, brake ducts, etc.). Has anyone successfully found the cause for this? It was missing the foam blocks, maybe that is the reason?
