Stealth mode?
Old Oct 3, 2006 | 10:21 AM
DC_TypeR's Avatar
1.) Remove the overhead console (1 screw), pull off the light cover then there is (2 10mm bolts) , then unhook the harness.
2.) Once it is out, you have to take out the carpet from the sun glass holder.
3.) Clean the surface really good with alcohol.
4.) Make a nice size hole in the upper right hand side of the sun glass holder
(to fit the portion of the SAFC harness through).
5.) Position the SAFC2 in the correct viewing position, cut 2 pieces of double sided tape, and stick it to the sunglass holder
6.) Run the harness from the SAFC2 though the hole you just made in the sun glass console up through the headliner and towards the passenger side a-pillar.
7.) Remove the sun visor on the right hand side (2 screws)
8.) Remove the weather stripping along side the a-pillar
9.) Remove the A pillar (right side, clips)
10.) pull the head liner down slightly, so you can grab the harness from the SAFC2 and leave it by the a-pillar.
11.) Remove the glove box (pop the left hand piece out, and let the glove drop down, and unhook it)
12.) The ECU is now exposed, remove the 2 10mm bolts on the top, and 1 10mm bolt on the bottom. The ECU will now drop down to the floor board.
13.) Remove the plastic piece on the right hand outer side of the dash
14.) Remove the harness from the ECU, attach your (plug and play ECU harness of choice)
15.) Run the “ecu” side of the SAFC2 harness from the ECU, up through the dash (right side) up to the A-pillar (attach with zip ties to the tweeter speaker wire) and then plug it into the SAFC2 harness at the top of the a-pillar!
16.) Re-install and put back everything you just took off! And start tuning!
Old Oct 4, 2006 | 02:14 PM
DC_TypeR's Avatar
also posted this in the how to section!
Thanks for all the kind words fellas!
Old Oct 4, 2006 | 02:30 PM
PKEVO8's Avatar
i didn't even know evos had sunglass holders....
Old Oct 4, 2006 | 02:46 PM
Spooldyou's Avatar
Nice! Glad to see that some one took thier pride on the install
Old Oct 4, 2006 | 03:03 PM
JondemandSales's Avatar
Very nice!!
Old Oct 4, 2006 | 03:19 PM
Novtec1's Avatar
Veteran: Army
damn, i actually thought about doing that with my sbc-id and speed meter...nice
Old Oct 4, 2006 | 03:21 PM
TURBOWHT's Avatar
Looks good.
Old Oct 5, 2006 | 02:05 PM
nashmage's Avatar
haha very good idea to have that up there and looks really clean.
Old Oct 5, 2006 | 03:02 PM
GOLDEVOVIII's Avatar
I had my HKS-EVC up there and my car got broken into and they didnt find that but they got my radio and cds good install looks good!!
Old Oct 6, 2006 | 07:12 AM
DC_TypeR's Avatar
Thanks guys!
I'm glad to see that so many of you like this idea!
DC_TypeR
For Sale - Cars For Sale
Apr 15, 2007 10:19 PM
EvolutionIX_MR
Feb 10, 2007 06:45 PM
EvolutionIX_MR
Nov 24, 2006 07:34 PM
EvolutionIX_MR
Oct 23, 2006 12:14 AM
webguy330i
Apr 12, 2004 11:53 PM
