how do i remove the rear wing
Old Oct 3, 2006 | 07:45 PM
evobeatsti's Avatar
i was just curious as to if it was easy. i have an autocross this weekend and would like to shed an extra few pounds. if anyone can tell me how to take off the wing that would be great.
Old Oct 3, 2006 | 08:12 PM
evobeatsti's Avatar
anyone know?
Old Oct 3, 2006 | 08:14 PM
idriveanevo's Avatar
remove the 2 10mm nuts and 2 10mm bolts under the deck and bump stops then with a lil force pull straight up. it should be stuck on with double sided tape
Old Oct 3, 2006 | 08:17 PM
evobeatsti's Avatar
is it something i can take off and put back on if i dont like it?
yea...
Old Oct 3, 2006 | 08:21 PM
AZ EVO IX MR's Avatar
any meledoies for taking it off of the sticky tap, doesnt seem like it wants to come off
Old Oct 3, 2006 | 08:25 PM
kinda pry back and forth on it, also use a hairdryer to heat up the tape. just be sure not to dent the deck lid... aluminum dents easy
Old Oct 3, 2006 | 08:30 PM
tuffguy's Avatar
It's better if you have a friend (two would be even better) to help you and if it's been in the sun to soften it up. Unscrew all the bolts. Now the tricky bit.
You'll need some insulated wire to "cut" through the tape. As your friend is pulling on the wing, use the wire and a flossing/pulling motion to separate them. If you have a 2nd friend, have them push down on the trunk as the tape is strong enough to screw up your trunk lid.
It's pretty easy, and should take no more than 5 minutes.
mine
Old Oct 3, 2006 | 09:50 PM
EVO<VR4's Avatar
Old Oct 3, 2006 | 09:51 PM
EVO<VR4's Avatar
Flossing is always a good technique, then follow with some mild detergent and water to clean the residue. If you got OCD, then get some painter tape for the holes left behind.
807JDM
Sep 11, 2016 01:59 PM
Bigasshammm
09+ Ralliart Show and Shine
Mar 29, 2016 03:15 AM
samer
Lancer How Tos / Installations
Jul 10, 2008 05:57 PM
showoff
May 27, 2004 05:37 PM
bri'sevo
Feb 3, 2003 10:53 AM
