help with rims
you're a little off there buddy. the RS's in that size aren't that light. the CE's are a little over 17lbs, but the advans are at least a pound and a half to 2 pounds heavier if not more in that size. on top of that, they aren't nearly as strong. it's also easier to find an offset in the Volks that fits the EVO without fender rolling or stretching tires that don't fit.
if there was a poll i would vote for the gunmetal advan rs. if it was me i would get gold though https://www.evolutionm.net/forums/sh...ht=gold+advans
The diamond black CE's were a limited run for team ralliart a year or so back...this is why all of you have been having trouble trying to find a set. Just my $.02
I would go with a set of CE's then have them powdercoated in black...ta da you win...with a bit of $$ of course
i was planning on getting the gtr face if i get them. just cant figure out if i like them better then the ce's. i like the ce's better at first but now its the rs. just all confused. so sauve how would you compare the two if you didnt have either and had to make a decsion
Whoa whoa whoa. Suave, the last time I saw your car, it had a set of TA CE's on it. The red lip with your red car was the best look I have seen with those wheels. Please keep them.
This should help...
Diamond Black ce28n's 18x8.5 +30 offset
Good luck finding a set though...the body shop curbed one of mine and I've been looking for someone that sells them and have been unsuccessful so far.
Let me know if you do find someone though, or already know where you can find them.
wow man look good. have you talked to cal at speed element he is usually pretty good with finding things
if i can get an aggresive offset with out having to go bigger and without rubbing issue's then i am sold on the ce's and like you said the rs are a lil expensive for a cast wheel but look so nice
FLOW1
22
Jul 21, 2008 09:54 AM
robyn402
Feb 10, 2008 12:10 AM
MitsuLancerTO
Apr 27, 2005 06:17 AM
