Powdercoat Results - MR BBS wheels
Subscribe
Jan 14, 2007 | 10:35 AM
  #46
very very clean...can't wait to see em on
Reply 0
Jan 14, 2007 | 11:41 AM
  #47
Quote: Got my wheels back from powdercoat and snapped a few pics of the results. They came out great, the inside, hub, and face all are perfect! They sure do look great with the black BBS center caps.
Rims look great, I am assuming it is a high-gloss finish? Did you also powder coat the lug nuts?
Reply 0
Jan 14, 2007 | 11:56 AM
  #48
very nice
Reply 0
Jan 14, 2007 | 12:08 PM
  #49
Very nice looking wheels
Reply 0
Jan 14, 2007 | 12:15 PM
  #50
i likeeeee
Reply 0
Jan 14, 2007 | 01:34 PM
  #51
Sweet. They look like the FQ400 wheels, just BBS style
Reply 0
Jan 14, 2007 | 01:51 PM
  #52
BUMP FOR THE POST POWDERCOAT WEIGHT BEFORE YOU PUT THE TIRES ON. i'd like to know that too because i'm planning on doing the same thing to mine. looks badass
Reply 0
Jan 15, 2007 | 10:37 AM
  #53
did this guy dissapere???
bump for many missed question's.
befor and after weight's of the rims.
how much
what kind of powdercoat did they use
where is this shop located
whats there phone number
Reply 0
Jan 15, 2007 | 10:40 AM
  #54
I like them.
Reply 0
Jan 15, 2007 | 10:48 AM
  #55
clean
Reply 0
Jan 15, 2007 | 02:26 PM
  #56
how much
before and after weights of the rims.
I don't have an accurate scale, but I would assume the new powdercoat would balance out (or close to) the removed finish, and not be a noticeable gain over the stock 18.5 lbs. Not sure
how much
See post #12:
Quote: I took them to one of many local finishing shops. They originally estimated me at $60 a wheel, due to the need for glass bead stripping because they're forged aluminum. Turns out the guys only charged me $200 flat when I went to pick them up :gotme:
I didn't know there was different types of powdercoat. I just told them high gloss black, so they used black powdercoat as well as a clearcoat powdercoat.
The shop is called Buffalo Finishing Works, in Buffalo, NY. The phone number probably wouldn't help since you're in NJ.
I had a wide variety of shops to choose from in the area, I can only assume that there are many finishing/powdercoating shops in your area.
I'd check google, the internet is an awesome resource
Reply 0
Jan 15, 2007 | 06:31 PM
  #57
Came out great.
Reply 0
Jan 15, 2007 | 08:17 PM
  #58
Did you specify a low-heat powdercoat? The higher temps associated with powdercoating can weaken forged wheels.
Reply 0
Feb 5, 2007 | 05:11 PM
  #59
I dont think <400 degrees is gonna hurt the metal.
Reply 0
Feb 5, 2007 | 06:41 PM
  #60
Quote: I dont think <400 degrees is gonna hurt the metal.
What are you basing your opinion on? Forged wheels can and do weaken with high heat applications. Do a search on it.
Reply 0
