Zeitronix install
Old Jan 31, 2007 | 03:28 PM
VenomEVO8's Avatar
Originally Posted by Evo Girlie
i mounted mine like every other joe ontop of the steering colum with double sided tape, i might remove it from there cuz the glare sometimes does not let me see the numbers, the custom job is great. I wouldnt want it showing though cuz dumb people will break ur window anytime they see something hanging there.
Im that Average Joe also.... on top of the steering wheel
13EVO13's Avatar
Here is mine, i cut the top of the steering column cover then it sits level and i can still see all my other stock gauges.
Old Feb 1, 2007 | 05:49 AM
Evo Girlie's Avatar
even bending my head i could not get a good look of what u did, can u post better pics??? maybe daytime ones???? what u described seems like a good idea
Old Feb 1, 2007 | 05:51 AM
EVOtagger's Avatar
Originally Posted by TheTumblerIX
Has anyone done anything that's a little more "built in" looking? I'm really trying to avoid something that looks, for lack of a better term, tacked on. I'm thinking of getting something made to put it into the radio opening, and moving the radio with the relocation kit.
yea, i tried that...the only problem is you wont be able to use the peak display function. You have to have access to a yellow button that is on the side of the display. If you mount it flush, you wont have access to that button and the peak display function is very handy
Old Feb 1, 2007 | 05:55 AM
SlowCar's Avatar
there is a green scratch protection plastic sheet over the screen out of the box...
does the display get "brighter" after its removed?
Old Feb 1, 2007 | 06:25 AM
BADEVO's Avatar
It does a little Abner but its not that bad. Not over powereding in any way.
Old Feb 1, 2007 | 09:29 AM
Evo Girlie's Avatar
yea it actually looks off white not greenish, i took mine off yesterday because with the heat it started getting little bubbles. BTW once its off its a pita to see when the sun is relfecting on the car so i opened the sunvisor or w.e is called and there is no glare .
also if u don't like it w/o the green overlay u can always put it back it will still stick
Old Feb 2, 2007 | 03:28 PM
ace_2822's Avatar
More pics!
Old Feb 2, 2007 | 09:25 PM
theretardtim's Avatar
i personally like the way eficker mounted his: https://www.evolutionm.net/forums/sh...&postcount=169
Old Feb 2, 2007 | 09:41 PM
SlowCar's Avatar
this is where i put mine.
Old Feb 2, 2007 | 10:37 PM
Drift4's Avatar
That is a clean mount.....i like also that the trim around the upper console was replaced to match the finish if the dash
Old Feb 5, 2007 | 09:57 AM
Evo Girlie's Avatar
bump for more pics
Old Feb 5, 2007 | 02:24 PM
EVOtagger's Avatar
Like I said, it looks nice, but you lose a very useful function of the display
Old Feb 6, 2007 | 02:53 AM
sandm's Avatar
here is mine.
realize you lose the yellow peakhold button, but I use mine mostly for datalogging, so the peakhold is not needed, as your peak is displayed on the graph.
wish zeitronics and others would make a din sized controller.
Old Feb 6, 2007 | 03:38 AM
90GSX-03EVO's Avatar
...Or he has an RS.
