3M Clearbra on my IX SE.
Old Mar 4, 2007 | 05:01 PM
  #31
yesevo's Avatar
cool i try to install 3m clear bra. and messed up.
and i did on all the side doors and side panel too.
and i took it off again/
well now i want my front bumper and hood done.
i see some nick and chip too. eventhoug i drive carefully.
clear bra is a must for brand new car~
Old Mar 5, 2007 | 10:02 PM
  #32
underworldfury's Avatar
it looks really good.
Old Mar 6, 2007 | 05:05 AM
  #33
TurboRush's Avatar
3M clear bra FTW. If you do any driving where there is even the potential for snow and hence sand a salt, its a must.
Old Mar 6, 2007 | 09:36 AM
  #34
4G63's Avatar
very true...but its not just sand and salt, its Anything thats on the road. Wood chips, busted up retreads, pebbles and gravel, etc, etc,... It may not be cheap, but its worth it in the long run!!!
Old Mar 6, 2007 | 02:55 PM
  #35
awd4u22's Avatar
definetly getting that clearbra for my next road trip....i just called for priceing accually
Old Mar 6, 2007 | 03:02 PM
  #36
awd4u22's Avatar
if anyone that has queastions on this clearbra like i did here is some question answer from the website 3M.....
Maintenance and Removal
Q. Will Scotchgard™ Paint Protection Film harm the painted surface if the film is removed?
A. If the film is properly applied to a fully cured painted vehicle, it can be removed, usually in one piece, without damaging paint surfaces beneath the film.
Q. Can Scotchgard™ Paint Protection Film be applied over a vehicle that has had the paint touched up?
A. 3M recommends that any repainted surfaces on your vehicle be professionally painted and fully cured before applying paint protection film. If you have touched up scratches or chips with a tube of "touch-up" paint and then apply paint protection film over it, the film will protect that area until it is removed. If the paint protection film is removed, it is possible that the area around the non-professional touch-up paint could peel off.
Q. Will the paint smear if Scotchgard™ Paint Protection Film is applied over a newly painted vehicle?
A. The paint on a newly painted vehicle must be cured according to manufacturer's recommendations. Your body shop should be able to provide you with this information.
Q. Can you paint or apply a clearcoat over the Scotchgard™ Paint Protection Film?
A. No, this is not recommended and is at your own risk. 3M film is supplied with an OEM-approved clearcoat which is not formulated to be over-printed, painted or clearcoated.
Q. Can I cover the whole vehicle with Scotchgard™ Paint Protection Film?
A. It is possible, but the application would be difficult and expensive. This product is really intended for the most vulnerable areas of the vehicle.
Q. Can Scotchgard™ Paint Protection Film be applied over graphics?
A. The clear film will not interfere with vinyl or painted graphics and is designed to match the gloss levels of today's automotive factory clearcoat paint systems, providing virtually invisible protection. However, if the Scotchgard™ Paint Protection Film is removed, damage may occur to the underlying graphic during the removal process.
Q. Can Scotchgard™ Paint Protection Film be used on headlights, foglights or windshields?
A. No, the Department of Transportation does not allow any film of any kind to be put on headlights, foglights or windshields.
Q. Does Scotchgard™ Paint Protection Film stick to bumpers?
A. Yes.
Q. Does Scotchgard™ Paint Protection Film stick to plastic?
A. Yes.
Q. Can Scotchgard™ Paint Protection Film be used on boats or other watercraft?
A. Yes. Marine requirements are different than automotive, so it is important to contact 3M's Marine Trades Division for information on these applications. For specific information, please call 3M Marine at 1-877-366-2746 for assistance.
Q. Can Scotchgard™ Paint Protection Film be used on aircraft?
A. Aircraft requirements are completely different than automotive, so it is important to contact 3M's Aerospace Division for information on these applications. Please call 1-888-364-3577 for assistance or use the on-line 3M Aerospace Contact Us form.
Q. Can Scotchgard™ Paint Protection Film to used for signs?
A. The film would probably stick, but you would need to test any specific application. 3M has no specific testing data for signs, so no warranty can be offered.
Q. Does Scotchgard™ Paint Protection Film resist yellowing?
A. Yes, it resists yellowing because the film is constructed of thermoplastic urethane, a tough, conformable material that is covered by a clear coat layer. The film and clear coat layers contain UV protectants to counteract harmful ultraviolet rays that can cause yellowing.
Q. Does Scotchgard™ Paint Protection Film come in colors?
A. Scotchgard™ Paint Protection Film is available only as a clear film. This feature makes the film virtually invisible while protecting the beauty of your vehicle.
Q. How is Scotchgard™ Paint Protection Film maintained?
A. Once applied, refrain from washing the vehicle in an automated car wash for 24 hours. Washing after that time presents no problem, and no special care need be taken for the film.
Q. Can I use wax over Scotchgard™ Paint Protection Film?
A. Yes. When waxing the vehicle, some wax may build up along the film edges. This can easily be removed when dry with a soft cloth, such as a 3M™ High Performance Cloth. Do not use any waxes containing dyes or waxes that are not recommended for urethanes. Abrasive polishes and/or rubbing compounds are not to be used.
Q. What products does 3M recommend to best maintain Scotchgard™ Paint Protection Film?
A. 3M makes a variety of products to help maintain the beauty of your vehicle. 3M™ Car Wash Soap (3M Part #39000), 3M™ Show Car Paste Wax (3M Part #39526 and 3M™ Perfect-It Show Car Liquid Wax (3M Part #39026). The best surface cloth to use is the 3M™ Perfect-IT™ III Detailing Cloth (3M Part #39016) since others may scratch the surface of the film.
Q. How is Scotchgard™ Paint Protection Film removed?
A. If desired, film can be removed at any time by picking up a corner of the film and pulling the film off the vehicle surface at a 90-degree angle. If the film has been present a long time, or if the film and vehicle are cold, a heat gun or hair dryer may be used to soften the adhesive, allowing easier removal. If any adhesive remains on the vehicle after removal of the film, it can be removed by using 3M™ General Purpose Adhesive Cleaner (3M Part #08984), according to the package directions.
Q. If Scotchgard™ Paint Protection Film is removed from the vehicle, can it be re-used?
A. Once the film has been applied and set, the adhesive will not stick a second time.
Q. After Scotchgard™ Paint Protection Film has been removed, how do I get any excess adhesive off my vehicle?
A. If any adhesive remains on the vehicle after removal of the film, it can be removed by using 3M™ General Purpose Adhesive Cleaner (3M Part #08984), according to the package directions.
Q. What if Scotchgard™ Paint Protection Film is installed incorrectly?
A. Contact your Scotchgard™ Paint Protection Film professional certified installer immediately.
Old Mar 6, 2007 | 03:08 PM
  #37
ries's Avatar
nevermind...answered my own question....
looks good btw
Old Mar 6, 2007 | 03:10 PM
  #38
awd4u22's Avatar
lol yea i was bout to show u....
Old Mar 8, 2007 | 07:29 PM
  #39
MyEvoDream's Avatar
great info, i googled it first, but this is what I like to see, it seems pricey, but it'll definitely be worth it for the road trips (dead bugs on the front bumper) and the rallying dust and rocks!
Old Mar 8, 2007 | 07:38 PM
  #40
EzNateZ's Avatar
Not bad.... now I want a clear bra on my girlfriend...
Old Mar 8, 2007 | 08:21 PM
  #41
bchang's Avatar
Can you use the 3M clear bra on aftermarket bumpers?
Old Mar 9, 2007 | 06:27 AM
  #42
Juice33's Avatar
Probably, if the installer is careful it should be all good.
However, I know mine was completely cut by computer, so there probably isn't a program for your aftermarket bumper. But there has to be guys that still do it by hand I would assume. I guess you would have to ask you local guy how he does it and if he can do it.
Old Mar 9, 2007 | 12:28 PM
  #43
davidvi's Avatar
Had this done last weekend, front bumper, whole sideskirt, behind front wheels and rear wheels.
Old Mar 9, 2007 | 03:34 PM
  #44
rjdevo9_mr's Avatar
i had starshield armor on my 3 previous cars and it truly was worth every penny, especially if you have a long commute or you drive long distances. even after several years, the bumper & hood still look good (all without those annoying rock chips)
4G63
Mitsubishi TC-SST Discussion
13
Sep 22, 2008 06:35 PM
4G63
31
Mar 31, 2007 02:53 PM
