Old Dec 4, 2007 | 11:19 PM
  #1516
DrivelineSales's Avatar
One of my fav setups:
Old Dec 5, 2007 | 12:48 AM
  #1517
timmiii's Avatar
I like it too.
Old Dec 5, 2007 | 01:15 AM
  #1518
evolutong's Avatar
Thumbs up great thread!
this is one of the best thread i've seen. not only it's the ultimate agressive wheel thread but i think it's the ultimate agressive evo thread. it rocks!!
Old Dec 5, 2007 | 09:14 AM
  #1519
M3this's Avatar
From: Where you come to vacation and go home on probation! Vegas!
I have been asking for it to be a sticky ... but it never happens
Old Dec 5, 2007 | 10:04 AM
  #1520
This thread deserves to be a sticky
Old Dec 6, 2007 | 11:25 AM
  #1521
diiirk@AwdMotorsports's Avatar
what offset in the rpf1's would be needed to have this aggressive look. can it be done with say a 35 offset and some spacers?
Old Dec 6, 2007 | 11:38 AM
  #1522
Speed Element's Avatar
^ that offset is +15
18x9.5 +15.. the rear fenders need to be pulled, rolled or shaved. The car was running 235/40/18s.. so if you wnat to run larger sized tires, you would need to run more negative camber.
Old Dec 6, 2007 | 12:10 PM
  #1523
gotspeed's Avatar
yeah spinner.........#$%^&%##%#%%^%^!#$#$%*&^&*^(&*^#$$ @#%!
Old Dec 6, 2007 | 12:36 PM
  #1524
XK120's Avatar
Would those wheels require spacers?
Old Dec 6, 2007 | 01:02 PM
  #1525
so there is now way to get a similar aggressive look with rpf1's without all the fender pulling, rolling and negative camber
Old Dec 6, 2007 | 01:15 PM
  #1526
CEB Unit's Avatar
For the ones that asked these are 17x10 +18 F and +38 rears with pulled shaved front fenders and same in the back. Wrapped with Nitto NTO1's
Old Dec 6, 2007 | 01:49 PM
  #1527
Can i acheive something similar to this look with a 245/40/18 tire on a 18x9.5 +38 offset with spacers and some fender work?
Or do i want to go with a +15 offset and roll the fenders?
Old Dec 6, 2007 | 03:12 PM
  #1528
CEB Unit's Avatar
I'm not sure. Try Speed Element since I know they like running nice offsets and they have a good deal of experience with many wheels.
Old Dec 6, 2007 | 03:44 PM
  #1529
rsalicrup's Avatar
18x9.5 in 38mm offset with some spacers.
Old Dec 6, 2007 | 04:33 PM
  #1530
Enkei RPF1 18x9.5 5x114.3 +15offset.
Tire size: 245/40/18s
Rear fenders are rolled and pulled slightly.
More pix for your viewing pleasure
IIRC the camber is set at around -2 or -3 in the rear.
If you plan on running 265+ sized tires, I suggest you should go with slight higher offset with stock fender setup
Gram Lights 57 Maximum or Optimize offer very nice aggressive offset for EVOs. Still require fender rolling and pulling a bit.
I usually recommend my customers to go with 18x9.5 +22s
+15 if you are going with Voltex or any other wide fender mods.
Hope this helps!
Happy Holidays!
