Old Jul 3, 2010 | 09:39 AM
  #4591
aguilar45's Avatar
Originally Posted by R/TErnie
I've got some better pictures of my car with the new suspension and rubber
Nice TB! Sticky icky icky....ooowee
Old Jul 3, 2010 | 09:56 AM
  #4592
Astro_Train's Avatar
Veteran: Navy
^^ looks great, seen other people run this set up b4 but your car is really low... you rubbing at all?
Old Jul 3, 2010 | 10:29 AM
  #4593
wasFWDnowAWD's Avatar
^take notes fellas, wide wheel WITH wide tires & still pretty flush
Old Jul 3, 2010 | 12:09 PM
  #4594
R/TErnie's Avatar
18x9.5 +40 NT03's
285/30/18 Hoosier R6's
-3.7 degrees up front
-2.0 degrees in the rear
whiteline RC kit, front + rear bump steer, and FLCA bushings
Energy suspension rear trailing arm bushings
Skunk2 Pro-C coilovers (10k front/12k rear) + camber plates.
Old Jul 3, 2010 | 07:18 PM
  #4595
veilside prius's Avatar
gotta camber them babies in... I'm gonna go back to Roger Kraus and run -2 all around
Old Jul 8, 2010 | 06:59 AM
  #4596
Blitz's Avatar
18x9.5 +40 NT03's
On stock fenders?
  #4597
Blitz's Avatar
Anyone have pics of RPF1 18x9 +35?
Old Jul 8, 2010 | 09:02 AM
  #4598
R/TErnie's Avatar
yeah on stock fenders.
You need a 3mm spacer in the rear to run the 285's!
There is also two metal tabs that attach the e-brake and the ABS line to the trailing arm in the rear...this needs to be trimmed to be flush with the trailing arm. I would also suggest grinding off the casting flash on the trailing arm for more clearance.
Old Jul 8, 2010 | 09:53 AM
  #4599
tweakdsm's Avatar
Originally Posted by Couch
Such a drastic change, coming from the vw culture. Wheels are redic sizes, yet sit flush.
true, thats why i think 255/35/18 is perfect tire size... you just have to play with wheel/offset.
Old Jul 8, 2010 | 10:07 AM
  #4600
tweakdsm's Avatar
Old Jul 8, 2010 | 10:20 AM
  #4601
nightwalker's Avatar
Not well thought out ^ Over done.
Old Jul 10, 2010 | 06:45 PM
  #4602
Paulevoxi's Avatar
My friend Chis
[IMG][IMG][/IMG][/IMG][IMG][/IMG]
Old Jul 10, 2010 | 06:53 PM
  #4603
boostedwrx's Avatar
^ What is that stock offset??
Old Jul 11, 2010 | 03:35 AM
  #4604
freshjuicebox's Avatar
just a little tease... wheels are 18x9.5+15 enkei rpfs and tires are 235/40 hankook v12 evos... ill be dropping the car some more, and a proper photo shoot is soon to come.
Old Jul 11, 2010 | 03:48 AM
  #4605
evobros's Avatar
post pics dayum!
