Old Apr 7, 2011 | 07:58 PM
  #5641
Joemflsxe's Avatar
Originally Posted by rdwngs44
it's never an issue to fit wide wheels and tires, it's all about how low you lower the car, you can fit 295+ on 10.5 wide wheels if it's raised up enough.
When you get into crazy wide tires (rt/ernie), you start rubbing control arms and suspension parts.
Pretty sure R/TErnie DOES run 295's on a pretty low stock body car.
Old Apr 7, 2011 | 08:27 PM
  #5642
Evoluvin's Avatar
Originally Posted by EVO.C
one more pics.
-3.5F , -4R camber
Could you take a pictures closer up of the wheels? I was thinking of running a 225 on a 9.5 rim.
Old Apr 7, 2011 | 09:09 PM
  #5643
stockEVO_8's Avatar
recent..
Old Apr 7, 2011 | 09:23 PM
  #5644
rdwngs44's Avatar
he's on 10'' +38, not a super aggressive offset on 295's and it depends on how you describe "pretty low". My point is that you cant just give someone info on how to fit aggressive wheels/tires without knowing how low they sit because that is way more important than what fender mods need to be done.
Old Apr 7, 2011 | 09:57 PM
  #5645
BrendanS's Avatar
word, couldn't have agreed with you more
Old Apr 8, 2011 | 12:13 PM
  #5646
essjEVO's Avatar
+2
Old Apr 8, 2011 | 12:30 PM
  #5647
R/TErnie's Avatar
Like DFV's with 6" Swift/Hyperco springs to clear the tire inboard... adjusting caster to clear as well.
Making Chromoly rear trailing links w/Howe ball joints to clear the tire in the rear?
Yeah... they'll fit. And I didn't have to do an EvoDave fender mod to make my 295's tuck.
Old Apr 8, 2011 | 06:45 PM
  #5648
BrendanS's Avatar
^props for tucking 295s
Old Apr 9, 2011 | 06:36 PM
  #5649
NocturnalEVO's Avatar
Originally Posted by stockEVO_8
recent..
moreee!
Old Apr 9, 2011 | 11:48 PM
  #5650
JdmGraphiteMR's Avatar
heres the set up for 2011 guys hope you enjoy it its a little teaser video my cousin shot for me ill have a full video pretty soon after we finish up with my other front end set up...thanks for looking the wheels are 18x11 +0 front, and 18x11 -5 rear, 295/30/18 all around.....i know some will like it some will hate it....but all comments welcome!
http://youtube.com/watch?v=EKhlFphYzJY
Old Apr 10, 2011 | 12:29 AM
  #5651
R/TErnie's Avatar
JdmGraphiteMR,
Did you learn anything interesting while making those wheels fit? Do you have adjustable caster? Any custom suspension bits?
Old Apr 10, 2011 | 01:00 AM
  #5652
no nothing everything fit up....i just took a chance when ordering them...offset is fine...not hitting my shocks...no custom suspension bits to make the wheels fit....just on some rsr coilovers and thats about it sir...but they use to be a +5 offset all around hi disk front and low disk rear, front has a 5mm spacer, and rear a 10mm spacer, and i got extended studs...
Old Apr 10, 2011 | 05:59 AM
  #5653
rdwngs44's Avatar
Y
That's about the same size wheel I'm running when you take the spacers into consideration, I'm at 18x10.5 -30 but you are running much wider rubber (I'm on 255). I was thinking and 12" wide wheel +15 range would work with the cyber widebody but you have a much lower offset on an 11" wide wheel. I'll try to snap some pics of mine for comparison.
Nice fitment!! Not a lot of wheel choices at 11" or 12" wide haha!!!
Old Apr 10, 2011 | 06:40 AM
  #5654
Charlie87's Avatar
jdmgraphiteMR
THAT IS ****ING HOT!
Old Apr 10, 2011 | 07:05 PM
  #5655
AdvanRG2's Avatar
JDMGraphiteMR, MOAR!!!
