Old Feb 28, 2013 | 11:07 AM
  #6916
evobros's Avatar
R ur rear fenders rolled? Is that rear bumper/fender bolt relocated? ^
Old Feb 28, 2013 | 11:14 AM
  #6917
vboy720's Avatar
yes to both.
Old Feb 28, 2013 | 11:17 AM
  #6918
evobros's Avatar
Then u shoud be fine. Also star specs don't run very wide.
Old Feb 28, 2013 | 11:32 AM
  #6919
chu's Avatar
chu
I disagree.
Old Feb 28, 2013 | 11:41 AM
  #6920
vboy720's Avatar
me too. thats why im going 255 this time around because star specs fit wide.
Old Feb 28, 2013 | 11:43 AM
  #6921
vboy720's Avatar
but im still stuck on the offset of the wheels. with 18x9.5+20 265/35 my fender was cutting the tire. Im not so sure if the +22 offset and 255 tire is going to be enough to make it tuck.
Old Mar 4, 2013 | 09:30 PM
  #6922
Knightr's Avatar
57dr
any one running 17x9 +22 with 255/40 and rolled fenders... any rubbing?
my car is lowered for pure track have to make sure they will fit within the well and not get all cut up... i have huge spring rates so compression not to much of an issue.
Old Mar 5, 2013 | 02:31 PM
  #6923
evobros's Avatar
Originally Posted by chu
I disagree.
I'm pretty sure I fitted 18x9.5+15 with a 245-40. So 18x9.5+22 with a 255-35 should be easy!
Old Mar 5, 2013 | 02:33 PM
  #6924
evobros's Avatar
I've ran 17x9+25 with 265-40 with rears rolled and bumper/fender bolt was relocated. Zero rub..
Old Mar 9, 2013 | 02:41 PM
  #6925
Knightr's Avatar
How people are fitting these with those sizes and offsets is beyond me...
unless you are running HUGE camber... -1.5 is all I need and want to run..... for my track setup..
check out my post...
https://www.evolutionm.net/forums/ev...-here-144.html
Old Mar 9, 2013 | 04:06 PM
  #6926
R/TErnie's Avatar
If you're racing on the track, don't come to the aggressive fitment thread. Search for the official wide tire thread.
And when you track your Evo enough you'll realize quickly that you NEED -3 degrees of camber at least up front.
Old Mar 9, 2013 | 04:10 PM
  #6927
R/TErnie's Avatar
Can you take some in-board clearance pics with the RPF1 in the rear? Just want to see how much space you have between the lower control arms.
buy some of my trailing links and you can run 10.5's in the rear
Old Mar 10, 2013 | 09:18 PM
  #6928
EvilTechnology's Avatar
How much are your links?
Old Mar 21, 2013 | 10:06 PM
  #6929
stockEVO_8's Avatar
Back up top
Old Mar 21, 2013 | 10:14 PM
  #6930
donnievo8's Avatar
sick set up
