Old May 8, 2015 | 03:45 PM
  #7336
FameEvo's Avatar
@joshms6 thanks brother. Specs are 17x9+22 and running 10mm spacers up front... Slightly rolled fenders in the rear
Old May 15, 2015 | 08:06 PM
  #7337
1SlowRS's Avatar
Anyone know anything about this setup by chance?
Old May 15, 2015 | 09:10 PM
  #7338
dookgvr4's Avatar
ccw evo fitment
Old May 21, 2015 | 06:17 PM
  #7339
kyle dettmann's Avatar
hey guys I'm looking for some varrstoen es2 wheels but I'm not sure if i want 18" or 19"... i found these pics online and was wondering if anyone knew if these were 18" or 19"? thanks!
Old May 24, 2015 | 09:29 AM
  #7340
NJ9MR's Avatar
FCOTM Winner
^ Please don't do that to your car!!!
Old May 31, 2015 | 09:24 AM
  #7341
SmurfZilla's Avatar
I like the color though.
Old May 31, 2015 | 01:08 PM
  #7342
Kada__85's Avatar
Those varrstoens are definitely 18"
17x10 rpf1
Old May 31, 2015 | 02:54 PM
  #7343
Solenoid's Avatar
Veteran: Marine Corps
17x10 rpf1
Way too high in the rear. What rear offset & spacer?
Re-set the rake & ride ht & its golden
Old May 31, 2015 | 10:15 PM
  #7344
buzzzin_IX's Avatar
Enkei RPF1's
Offset: +15
Camber: Rear -2.5
Tires: Yokohama S-Drive 255/35
Fender Mods: Rolled rear. Still need to do bolt relocation. Fronts haven't been touched.
Rubbing: At my current height the rear only rubs on big bumps and dips if im going fast. Doesn't rub on hard cornering.
P1080734 by steven nguyen, on Flickr
6 by steven nguyen, on Flickr
1 by steven nguyen, on Flickr
evo3 by steven nguyen, on Flickr
Old Jun 1, 2015 | 06:29 AM
  #7345
Originally Posted by buzzzin_IX
Enkei RPF1's
Offset: +15
Camber: Rear -2.5
Let me first say I really like the look
Secondly, a good example of how the +15 is very tough to fit correctly w/out adding out of spec camber & the need for some serious fender pulling
Old Jun 1, 2015 | 09:09 AM
  #7346
NJ9MR's Avatar
FCOTM Winner
My 2006 IX-MR:
Tires: Bridgestone Potenza RE760 Sport (245 X 35R18)
Rims: ADVAN RS (18 X 9 +29)
Rear fenders are rolled.
Old Jun 1, 2015 | 05:56 PM
  #7347
TreatsIX's Avatar
18x9.5 varrstoen es2
255 35 dunlops
Old Jun 3, 2015 | 07:08 AM
  #7348
polish_pounder's Avatar
18x9.5 +22 all around
265/35 tire
only modification is the rears are rolled
Old Jun 4, 2015 | 02:03 AM
  #7349
besk's Avatar
for trackday i would like to run on evo IX semislick 265/35 r18 with wheels 18X9.5 ET 22 or 38.
Will ET38 fit without problems on brake calipers and coilovers?
because i'm afraid to go ET22. i already run 235/40r18+ xxr527 18x8.75 ET20 and they touch often everywhere and 18X9.5 ET 22 will be 8mm more out...plus bigger tyres 265/35r18..
current situation on evo IX:
stock body
back fender rollered
back camber -2 ,front camber -3
bilstein pss9 (coilovers+springs) and quite low
i will appreciate lot comments
thanks
Old Jun 4, 2015 | 07:23 PM
  #7350
buzzzin_IX's Avatar
stock body
thanks
go with +38, +22 you will need fender work forsure. Its considered an "aggressive" offset. i know minusprevious can help you out with that question. he's very knowledgeable with fitments.
