PurePlayaers Unfinished Engine Bay Pics.
not to bash your set up at all but i love how people bash mine and it makes 10whp less with 2lbs less boost. i do realize the 35r will smoke my 3037s at high boost, so again im just showing the community something here.
HAHA just kidding Btw pureplaya u gotta love 6 pucks for daily driving huh? HAHA But on a track its great!
What would a stock evo 8 or 9 put on that mustang dyno, also whose dyno was used, CFT?
ah yes the manifold rust....I thought the coated manifold wasnt supposed to rust. I guess its not that thick of a coat.
It wouldnt be as bad if you could drill come holes inbetween the runners where it sits against the block..
No worries, my BR cast manifold looks the same, thats why I hav an arc ti cover on it
uh huh....
i hope you mean you plan on running 100% methanol injection, and not as the primary fuel...? you know on a FULL tank of meth as a primary fuel even in the city driving somewhat easy you'll get like 5 MPG? if you go to a HPDE or something you'll drain a full tank in like 15-20 minutes! as an example, i get 5 mpg at the track over a 20 minute session... running pure meth means you'll be moving from a 14.7:1 stoic fuel to a 6:1 stoic fuel... thus instantly you will require 2.5x's the amount of fuel. and sense we run the pump at lambda = .78, if you ran that with meth it would be 4.8:1 a/f. yikes!!!!!!! you would need like a quad pumper fuel system.
^Of course thats what he means.
Looks like it needs more work! For a car with a 35r I was expecting something pretty, but then again Im hard to please.
Have fun with the car kid, don't kill yourself with it.
uh huh....
Yes I meant a Meth pump, pumping 100% Methanol (not 50% meth 50% water or alky)
Yea, basically when im on a hill, (like the other day in the parking garage.) trying to get up is a B!TCH!.. The car shakes like crazy n it grinds under my foot uncontrolably.
that dyno is a high reading dyno...
my friend dynoed 330 there and trapped 110.... thats the only example i have... but i've raced a few people who dynoed 380-430whp there that i should have gotten spanked by and it was either close. win or lose by a little. they should have stomped me by a ton.
