Rota P45R Qustion?
Old Mar 1, 2007 | 04:26 PM
greybird's Avatar
Question Rota P45R Qustion?
I need some help with this , I just recieved my P45's from subydude and the question that i have is that on the fronts the wheels are 18x9.5 with +30 offset and a 8mm spacer to give caliper clearance and im not sure if the spline drive lugs they sent will be enough tread to grab onto, is the a extension or something?
Attached Thumbnails Rota P45R Qustion?-2554018.jpg   Rota P45R Qustion?-new-rotas.jpg   Rota P45R Qustion?-side-view.jpg
Old Mar 1, 2007 | 04:31 PM
eve-slow's Avatar
You're definetly going to need extended studs. Try RRE.
Old Mar 1, 2007 | 04:34 PM
greybird's Avatar
any idea where to buy them from and price?
Old Mar 1, 2007 | 05:24 PM
ctninea's Avatar
Hey sent u a pm those studs>>
Old Mar 1, 2007 | 06:29 PM
koffebean00's Avatar
I have the exact same wheels with the same offset and 8mm spacers and did not have to extend my lugs.
Old Mar 1, 2007 | 06:30 PM
Ultimate CC's Avatar
i don't think you need extended lugs...
Old Mar 1, 2007 | 06:36 PM
I want your tires!!
Old Mar 1, 2007 | 07:07 PM
greybird's Avatar
so i dont need the extensions, nice now all i have to do is roll the fenders and ill be in business
Old Mar 1, 2007 | 07:08 PM
greybird's Avatar
i gotta thank subydude for the goods they're the ish!
Old Mar 1, 2007 | 07:37 PM
I still haven't rolled my fenders yet, but I need to. I'm waiting on the shop to order a new fender roller. They lost their other fender roller or forgot who they loaned it out to last.
Old Mar 1, 2007 | 07:41 PM
greybird's Avatar
how bad is it without ur fenders rolled?
Old Mar 1, 2007 | 09:16 PM
Evotech8's Avatar
Has anyone tried to see how many turns on the lug nuts (w/stock studs) your seeing with 8mm spacers on?
I heard 6-7 full turns on the threads is the minimum for safety.
I'm debating whether to get extended studs with my P45R's if using 8mm spacers.
Old Mar 2, 2007 | 08:04 AM
I don't know..... but if my wheels fall off I'll let u know!
Old Mar 2, 2007 | 09:48 AM
CHIGGA73's Avatar
i'm using a 5mm spacer and it fits fine (a bit close i admit) but they haven't rubed or touched the calipers
no extended studs for me
Old Mar 2, 2007 | 10:44 AM
Evotech8's Avatar
Well, If 8mm spacers ends up being too thick for the stock studs, I might try machining the spacers down to 6.5mm for more thread contact.
Hopefully I can at least get 6 full turns on the lug nuts.
Keep you posted when I receive my P45R wheels on order.
