Worn Tires, help
Old Jun 8, 2007 | 07:32 PM
mitsuozboi's Avatar
Originally Posted by cfdfireman1
So alignment will wear inside and outside of tires at the same time evenly?
it depends what the camber and toe is set at.... factory specs are usually around neutral so that the tire wears evenly. as long as the tire pressure is correct and the tires are rotated.
Old Jun 9, 2007 | 08:38 AM
cfdfireman1's Avatar
I'm sticking with low air for exteded periods. If it was just the camber they would be worn on one side only.
Old Jun 9, 2007 | 08:47 AM
bluebyu36's Avatar
doubt it's the pressure.................
Old Jun 12, 2007 | 08:37 PM
http://www.familycar.com/CarCare/AlignmentBalance.htm
