UPDATE: Volks + Semi-Girthy Meats …
Love the wheels and tires, but the ride height looks unusually low. Is that the ride height that Robi suggested? I would think you'd be hitting the bumpstops constantly, not to mention the significant change in the relative roll centers front to back.
Canon EOS 300D (6.3mp Digital Rebel)
Thanks for the continued compliments!!!
Just applying more pressure with the fender rolling tool will pull it out more, but the quarters will begin to buckle. I've seen a few cars on here running aggressive offsets with the same dented quarter panel/pulled fender syndrome. Not for the squeamish.
There's plenty of room for the Evo. I had to yank it out for the pics!
Tyler … reading comprehension FTW, right?
Do you ever get back to Vegas?
Ed … see you soon bro! It's been a while.
I'll end up doing a shoot and starting a new thread when it's done.
Do you ever get back to Vegas?Ed … see you soon bro! It's been a while.
I drive the car a lot less now. With the wider setup, I may have to raise it a tad and run some heavier spring rates. But, I need to see how it behaves on track before any changes.
I can't wait man, SEMA is going to be cool, but so is Vegas' pump 100oct on the new setup.
In '05 spent more on gas IN Vegas than I did getting there and back.
You could avoid the dent by shaving the corner where the fender changes from over the wheel to over the bumper. I had the same problem as you fitting my 17x9.5 +25 RG2 with 17x255x40 NTO1s. I rolled and pulled my fender, but the corner, started to fold inside and created sharp tip. It won't go anywhere anyways, so applying a lot of pressure will only cause problems. I had no choice but to shave it with a dremel, and also had to shave the bolt that holds the bumper to the body right behind the fender.
I also have Robispec clubsport KWv3. After 1st autoX, I noticed that front weels are rubbing half of the fender lip under very hard turns. Had no choice but to roll them as well. They came out good tho.. My spring rates are 8K in the front and 9K in the rear.
Anyways, your car looks sick. Very well done
