brighter backup lights...
Old Nov 23, 2007 | 10:16 AM
mrfred's Avatar
If anyone has ever been annoyed by the lack of brightness of the stock 18 watt 921 backup lights (especially annoying with tinted windows), there are a few alternatives that I have found.
- ERD bulb - 35 W halogen bulb originally intended to be used with overhead projectors. Should be roughly 2x the brightness of stock.
- ERF bulb - 50 W halogen bulb also originally intended to be used with overhead projectors. Should be roughly 2.5x the brightness of stock. Note that 50 W is the power consumption of low beam lights on many cars and will generate quite a bit of heat. I don't know if they will melt anything if left on for an extended period of time.
Both of these have the same base as the 921 bulb and should be a direct fit. In looking around on the internet, I've come across several forums where people have used these lights with great success. The lights are a bit hard to find though. Seems like online camera shops and speciality light vendors have them. Prices vary from something like $25 ea to $8 ea depending on the vendor. Should all be the same items, so go for the less expensive ones.
Note, these are halogen bulbs, so only handle them with rubber gloves to keep oil and debris off the bulb.
Old Nov 23, 2007 | 10:22 AM
mitsuozboi's Avatar
the wattage is twice as much but that doesnt make them 2x brighter. they should be much brighter. halogen is a much whiter light. It is a good idea. Good info.
Old Nov 23, 2007 | 10:30 AM
svtkiller's Avatar
cool
Old Nov 23, 2007 | 11:28 AM
[GBU]Moon's Avatar
kudos!
Old Nov 23, 2007 | 11:39 AM
Jim in Tucson's Avatar
Originally Posted by mrfred
... halogen bulb originally intended to be used with overhead projectors...
Our EVOs are 12 volt DC and every overhead projector I've seen is 120 volt AC. What am I missing here?
Old Nov 23, 2007 | 11:55 AM
mrfred's Avatar
The bulbs are 14 V. Must be a transformer in the projector.
