Voltex EVO in wind tunnel
Old Mar 4, 2008 | 03:40 PM
  #31
ch53avitech's Avatar
Originally Posted by Jamdown
From what I remember the wind should go under the wing faster creating a downward force
Bernoullie(sp) effect I think .... not certain
I though Bernoulli's principle has to do with the increase or decrease of the speed of fluid being directly represented by pressure applied to that fluid. The greater the pressure applied the slower the fluid flows.
Old Mar 4, 2008 | 06:03 PM
  #32
evozakk's Avatar
That is completely bad ***...
Old Mar 4, 2008 | 06:38 PM
  #33
nothere's Avatar
a great deal of the flow follows the contour of the rear window. that is the area where the evo suffers. (the wing is catching cleaner air that has not been seduced by the roof line. The stock wing is a little low and a lot of its air is turbulent wash from the roof/rear window. greater airspeed brings some cleaner air to the wing.)
you see the pencil thin smoke line become very large, almost cloud like once it passes the roof line. basically it is a cloud formation area, once the air passes the roof it now has to expand to fill the new area over the trunk. it will need to bring more air in from where ever it can to fill the void. even to the point of pulling air from behind the car.
yarn was the original airstream indicator. don't know if the green line is something developed or just green yarn.
since the wing is an inverted airfoil there is lift pulling down. the air is traveling faster across the bottom surface... assuming air is "attached" to both surfaces and has not let go. while the wing is in the turbulent shadow of the rear window/ roofline very little air follows the airstream of the wing. when air speed has gotten to the point it deflects down more than breaks up is when the wing becomes useful. you can think of the roof line as an airfoil too. it is lifting, in the wrong direction.
Old Mar 4, 2008 | 06:46 PM
  #34
Mr. Stock's Avatar
already answered...
Old Mar 4, 2008 | 07:10 PM
  #35
Evo8's Avatar
like said before under freaking beliveable
Old Mar 4, 2008 | 07:16 PM
  #36
1131's Avatar
new wallpaper lol
Old Mar 4, 2008 | 10:00 PM
  #37
48mile's Avatar
very cool
Old Mar 5, 2008 | 03:14 PM
  #38
Fuel4Blood's Avatar
thats a bad *** picture
Old Mar 5, 2008 | 05:38 PM
  #39
jcdevo67's Avatar
thats sick...never seen one in a wind tunnel before
Old Mar 5, 2008 | 06:28 PM
  #40
keong72's Avatar
nice pic and got ap racing
Old Mar 5, 2008 | 06:37 PM
  #41
UT_Evo's Avatar
Already answered, I know, but I'll answer it again in a slightly different way, for anyone who still doesn't get it:
Where the air is moving faster (under the wing) there is less pressure than the force of air above the wing. So it pushes down as the wind moves under it faster and faster which decreases the pressure more and more. Same thing with airplanes only it is reversed. The air over the wing flows faster than under. So the goal is to get lots of really fast air to move under the wing, and as little as possible of air to move over the top.
Old Mar 18, 2008 | 10:12 AM
  #42
ELYTEVOIII's Avatar
That's a sick pic!!
Old Mar 18, 2008 | 10:15 AM
  #43
CrackerJackToy's Avatar
Nice, never seen that before.
Old Mar 18, 2008 | 10:42 AM
  #44
ForcedFedRS's Avatar
Always top notch stuff from Voltex!
Old Mar 18, 2008 | 10:50 AM
  #45
piranha's Avatar
http://en.wikipedia.org/wiki/Airfoil
Originally Posted by JordanS4
It looks like some air is hitting the wing and the rest that isn't going over top of the wing would still push the trunk down.
Chino051
Feb 24, 2016 12:12 PM
BPAuto
Dec 31, 2015 04:34 PM
DrivelineSales
Dec 9, 2010 02:09 PM
BPAuto
Aug 10, 2009 06:37 PM
evo_soul
Canadian Forum
151
Mar 25, 2009 07:56 AM
