APR Canard Question
Old Jun 5, 2008 | 07:33 PM
dragmod's Avatar
APR Canard Question
I just got mine in and both the top and bottom canards are exactly the same size. Is this correct for the evo? I downloaded the template for install and it looks like I should have two different sizes. Any feed back would be great.
Thanks,
MIke
Old Jun 5, 2008 | 07:40 PM
MitsuJDM's Avatar
I'm almost certain all four are the same size. They are pictured as two different sizes on some sites, but the ones for the Evo are all the same size.
Old Jun 5, 2008 | 07:47 PM
dragmod's Avatar
hm, that's odd. You would think that the bottom one would be larger. Also, if anyone has some experience with placement, I would appreciate it. They don't include angle direction or anything to help you install. I don't want them to just be good looking, I want them to be functional and provide ample down force for track driving. Thanks.
Old Jun 9, 2008 | 07:56 PM
dragmod's Avatar
bump for suggestion on install for canards. Thanks for any help.
Old Jun 9, 2008 | 09:34 PM
Goldfinger978's Avatar
as stated, all four are the same size. I recently had mine installed when my car was in the shop for a couple other things at CBRD. I'll be honest, I purchased them on looks alone to be frank. I like how they make the front end look so I basically let Mark put them where he thought they should go. Will the angle that he put them at make any more downforce than another? Not sure haha. Sorry I'm probably not helping at all with this lol
I'm sure someone with a bit more knowledge of downforce will chime in.
Old Jun 10, 2008 | 07:38 AM
CBRD's Avatar
i wouldnt consider them to be a downforce adding piece...
mostly for looks...
cb
Old Jun 10, 2008 | 03:55 PM
dragmod's Avatar
mostly for looks...
cb
really, they are supposed to help with downforce. I say false advertising if this really isn't the case. Thanks for the help. About what angle did you install them at and how high up front the ground and how far back from the front of the car. Thanks
Goldfinger, you may be better to answer those questions above then CBRD. If you could do some measurements, that would be super.
johnson81420
Jul 26, 2013 10:41 AM
Lancer_hta
Australian Forum
Mar 11, 2013 10:01 PM
EVO-8-YOU
Mar 30, 2007 11:52 AM
xepyt
Mar 11, 2006 07:22 PM
VtexGt3
Feb 26, 2005 03:32 PM
