my evo photoshoot
Old Nov 2, 2008 | 06:01 PM
EvoIXMR's Avatar
my evo photoshoot
Well, it was a nice fall day and I just finally got my car all done. It was a 1 year build for several reasons and I couldn't race it this year, but its ready for the next season. My best friend Jeremy (Prez on Evom) who had just gotten a D40 suggested we go for a photshoot since I got the car wrapped together. My buddy Casey also has a nice delsol that he auto-x's decided to go with for a cruise and some pics....Hope you like them!
Engine/Drivetrain:
- Full-race pro-street manifold HPC coated with EGT sensor on #2 runner
- FP Green port fully matched
- FP High performance wastegate actuator
- FP 2” SS outlet pipe (custom cut to work with ETS LICP)
- FP stainless 02 housing
- Greddy Racing Titanim cat-back exhaust (11 pounds)
- DC sports 3” Stainless downpipe (with catalytic convertor elimination). Downpipe tapped for wideband and DEI exhaust wrap.
- ETS 3.5” custom FMIC designed to fit Cusco power brace
- ETS 2.5” ultra-short route FMIC piping (silver powdercoat)
- ETS 3” intake and filter adapter (silver powdercoat)
- ETS mini-battery kit with battery (silver powdercoat)
- MIL.SPEC ported Intake Manifold with custom NPT bungs for Zeitronix MAP sensor, AEM boost gauge and BOV pressure sources
- MIL.SPEC 65mm ported/polished throttle body with re-built seals
- Hondata Insulated Intake Manifold Gasket
- NGK BPR8ES spark plugs
- Zaklee clear cam cover
- Ralliart plug wires
- Ralliart Thermostat
- Ralliart High Pressure Radiator Cap
- Tomei Thermostat killer
- Fluidyne 7” puller fan installed on oil-cooler
- AC removed and Evo VIII RS AC eliminator serpentine belt installed
- XS Engineering Racemax 272 cams
- XS Engineering Ignition Amplifier
- Crower dual Titanium Valve springs and Retainers
- ACT 2600 Clutch and street pressure plate
- AMS full length stainless clutch line
- Aeromotive fuel rail
- FIC 750cc injectors
- Saikou Michi DC3 Split catch cans (black)
- PCV valve elimination
- Mishimoto slim radiator with custom 13” puller fan and brackets
- Gates high-performance radiator hoses
- Perma-cool 13” pusher fan mounted in condenser fan location for extra cooling
- Powerflex solid side motor mounts
- AMS chromoly lower engine brace with solid bottom motor mount
- AMS Moustache brace eliminator and solid rear diff bushings
- TRE Ralliart LSD and T-case re-built by Jon Ripple
- TRE Rear differential upgrade (1 way clutch pack) and re-build by Jon Ripple
- Beatrush solid driveshaft bushings
- Sound deadening removal from underneath (removed as much as possible to reduce weight)
- Beatrush radiator cooling panel
- Perrin Short Shifter
- Billet shifter base bushings
- Billet shifter cable bushings
Suspension:
- Whiteline 24mm rear swaybar
- Whiteline 25mm front swaybar
- Whiteline performance front swaybar endlinks
- Whiteline performance rear swaybar endlinks
- Whiteline precision-steer kit
- Whiteline roll-center correction kit
- Whiteline front LCA bushing
- Whiteline rear LCA bushing
- Whiteline rear lower strut mount bushing
- Whiteline rear trailing arm bushing
- Whiteline rear toe arm bump steer kit
- Perrin Performance rear swaybar stout mounts kit
- Perrin Performance PRSR kit with offset caster bushing
- GT-Spec rear trunk cage
- GT-Spec 5 point lower ladder brace
- Beatrush front LCA braces
- Megan Track coilovers
- Cusco power front brace
- APR flex-control upper strut brace
- All arms were painted bronze and clearcoated
- Hub and knuckle were beadblasted and painted black
- All axles were painted black
Exterior:
- Chargespeed D1 20mm widebody FRP fenders (modified to shave blinker hole)
- APR front carbon fiber splitter
- APR carbon fiber dual canard setup
- Seibon Carbon Fiber trunk lid (keyhole painted black)
- Seibon Carbon fiber hood (OEM style modified by painting mesh black)
- APR GTC-200 Carbon fiber rear spoiler
- APR carbon fiber rear diffuser
- APR Carbon Fiber formula GT mirrors
- Lamin-X yellow headlight film
- Custom aluminum sunroof block-off plate (paint matched)
- Rexpeed black vortex generator
- Rexpeed Carbon Fiber cooling ducts
- Smoked taillights
- Custom front tow hook
Wheels/tires/brakes:
- Rota 18x9.5 P45R with 285/30/18 Kumho V710 (auto-x)
- Enkei 17x9.5 NT-03M with 275/40/17 Falken Azenis RT-615’s (street)
- Konig 18x9 Runaway Shadow Black with 265/35/18's (road-course)
- SSR 17x8.5 GT-7's with 255/40/17's (for crappy driving...lol)
- H&R 25mm wheel spacers
- Ichiba 10mm wheel spacers
- Hawk HP+ front and rear brake pads
- Teflon coated SS brake lines
- ATE super blue brake fluid
- Turned stock rotors
- OEM brake cooling air diverters
- Hotlap Motorsports brake cooling ducts
Interior/Electronics:
- Autopower 4 point rollbar with diagonal brace and driver’s side rear brace
- Beatrush performance floor brace
- Sparco 5 point SFI/FIA certified harnesses
- Works Bell Slim steering hub adaptor
- NRG 350mm deep corn style black leather steering wheel
- Corbeau FXPro racing seats
- Corbeau seat sliders
- Ralliart shift knob
- AEM truboost boost controller/gauge mounted on Autometer Steering pod gauge panel
- AEM Coolant temp, AEM oil temp and AEM oil pressure gauges mounted on Gruppe-S triple gauge pod
- Raptor performance shift-light custom installed on instrument panel garnish
- Zeitronix wideband display custom installed in clock location using S-AFC bracket.
- Zietronix ZAVT-1 custom installed in dash
- Zietronix ZT2 brain unit (boost and EGT options) installed in glovebox
- All door panels, seats, carpet, OEM seat belts, all plastic trim, unnecessary brackets removed to reduce weight
- All sound deadening removed including dash mat insulation behind dash
- Interior wiring harness was de-pinned to eliminate any unnecessary wiring (stereo, ETACS, power windows/locks, sunroof, SRS etc). Over 13 lbs of harness was removed.
- Full manual windows and door lock conversion from Evo VIII RS installed. Door panels will not installed to keep weight down
- Beatrush bulkhead division plate
- Tactrix and datalogging cable hardwired to car and accessible via glovebox
- Napolex 300mm wide rearview mirror
TUNED BY MELLON!!!!!
Old Nov 2, 2008 | 06:08 PM
purevibez's Avatar
looks good man
Old Nov 2, 2008 | 06:11 PM
hksevoix's Avatar
I'm likin the interior
Old Nov 2, 2008 | 06:17 PM
EvoIXMR's Avatar
^^^^ Thanks, man. Its strictly business. RS conversion, no sound deadening, no excess wiring. Heck, I would remove the dash, but I am keeping heat for now...lol
Old Nov 2, 2008 | 06:36 PM
Mellon Racing's Avatar
KC that thing looks killer ! man, one look inside the interior and you know you're in for one hell of a ride! I love it! I'm proud to be tuning it!
Old Nov 2, 2008 | 08:43 PM
Betty's Avatar
Oh my, speechless... love that blue bar in the front. Cusco?
Old Nov 2, 2008 | 08:44 PM
unlimited02's Avatar
thats a tight steering wheel... where did u get that AUTO BOTS emblem from...
Old Nov 2, 2008 | 08:51 PM
EvoIXMR's Avatar
Thanks so much, Chris. I appreciate all the work you doing to help me haul booty at the road course...
Old Nov 2, 2008 | 08:54 PM
Evolution IVGSR's Avatar
YA for Race cars Nice I like your car man
Old Nov 2, 2008 | 09:36 PM
FLOW1's Avatar
DAAM, what you putting down? Interior is sickness and love the plates, haha!
Old Nov 2, 2008 | 09:55 PM
EvoIXMR's Avatar
mellon and I are road-tuning right now, I don't care about the dyno or 1/4 mile no's....just how she does in corners
Old Nov 2, 2008 | 10:41 PM
Wayne99gsr's Avatar
Love the modified rear bumper!! both car look bad ***!!!
Old Nov 2, 2008 | 11:13 PM
EvoIXMR's Avatar
thanks man!
Old Nov 3, 2008 | 06:05 AM
Pr3z's Avatar
Ballin!!!!
Old Nov 3, 2008 | 07:11 AM
EvoIXMR's Avatar
LOL, Jer. You the one who took the "ballin" pictarz....Thanks much!
