My 2000 Evo 6 GSR
Old Feb 4, 2009 | 02:13 AM
Evo_Mic's Avatar
My 2000 Evo 6 GSR
Here is some pictures & build up of my Evo 6 GSR that I bought back in November 2007 from a friend.
When I bought the car it was fairly standard apart from an Exedy Clutch, Motec M800 Pro, ARP Rod Bolts, HKS Boost Gauge & Evo 400 Evo 9 Turbo
Here is the car when I first bought it:
After a mapping session to have the Evo 9 Turbo fully mapped I ended up with a few problems. Exedy Clutch gave up, so I put in a HKS Pro Twin plate (That then died after 2000k miles, got an Exedy Twin plate in now) & then the piston rings went after what I think was poor mapping due to running rich in low revs & then lean top end.
With the rings gone I decided to get a 2.3 Stroker put into the car from Extreme Motorsport with a similar spec to there UK 2008 Time Attack Car.
After the engine in & a quick run in the car was mapped at 2 bar of boost & made 400 bhp & 440 l/b at the fly. The car was restricted with std injectors, std intercooler & std exhaust. Since then I have put a 3" turbo back system.
Here is a few pic of the car when i went on a drive with my mate & his 350z
I had been doing this a few times that day
[/QUOTE]
I do have coilovers for it but Tien have an 8 week back order for new top mounts for it
The current spec is as follows:
Engine:
Extreme Motorsport 2.3 Stroker
JE Pistons
Oliver Rods
2.3 Crank
ACL Bearings
ARP Studs & Bolts through out
HKS Head Gasket
Piper Extreme Cams
Ported, Polished & Skimmed Head
Solid Lifters on the Exhaust Outlet
Hydraulic Lifters on the Inlet
Cusco Oil Catch Tank
Evo 9 GT Turbo
Koyo Radiator
HKS Filter but to be replaced with 4" K&N
Standard Injectors
Standard Intercooler
3" Blueflame Exhaust - Turbo Back
Carbon Slam Panel
Carbon Pug Cover
Carbon Cam Gear Cover
There is more but cant remember just now
Transmission:
Exedy Twin Plate Clutch & Flywheel
Standard 5 Speed Box
AYC Rear Diff (But unplugged & to be replaced with RS Diff)
Wheels & Brakes:
Standard Brembo 4 Pots on Front & Brembo 2 Pots on Rear
3G Discs & DS2500 Pads on Front & Back
Standard 17" OZ Super T's in Painted White with Hankook Track Tyres
Suspension:
Standard KYB Set-Up but do have Tien Flex Coilovers & EDFC Controller but waiting on new top mounts
Electronics:
Motec M800 Pro ECU
3 Bar Map Sensor - Got a 5 Bar Map Sensor to be fitted
Apexi AVCR
Exterior:
HID Conversion Kit
Carbon Vortec Generator
Carbon Exhaust Surround
Black Mud Flaps
The next things I am aiming to do to the car are 1000cc RC Injectors, Bigger Intercooler, Tien Coilovers (Once the top mounts are in stock), New 17" Compomotive Mo Wheels, RS Rear Diff, 5 Bar Map Sensor & 6 Pot AP's to fit under 17's. Once I have decided what turbo I am fitting I should be ready to slap it on & then go for the power.
Comments welcome.......
Mic
Old Feb 4, 2009 | 02:17 AM
TwoFour's Avatar
Oh yes! I like
Old Feb 4, 2009 | 03:26 AM
ohfourLancer's Avatar
i wish you left the foglights white
but looks good
Old Feb 4, 2009 | 04:39 AM
blueprint's Avatar
job well done, you did an excellent job of upgrading that car. was the evo9 turbo a direct bolt on? did it require any modifications?
Old Feb 4, 2009 | 05:36 AM
andreww238's Avatar
very nice !!
Old Feb 4, 2009 | 06:31 AM
porsherules911's Avatar
sweet
Old Feb 4, 2009 | 06:33 AM
Evo_Mic's Avatar
but looks good
One of the lenses got smashed from stones off the road, so when I bought new ones they only stocked them with a blue tint but they still shine white.
Blueprint, the Evo 9 turbo is a straight bolt to the 6 & I think most of the cars.
I havent had to change anything on the car to allow it to fit.
Old Feb 4, 2009 | 06:46 AM
Azntoyhere's Avatar
Nice car, how much does your car puts down now?
Old Feb 4, 2009 | 07:29 AM
Jakeg97's Avatar
sick ride
Old Feb 4, 2009 | 07:53 AM
4G63K's Avatar
All i can say is SICK!
Old Feb 4, 2009 | 08:01 AM
Jorda420's Avatar
looks great
Old Feb 4, 2009 | 08:05 AM
migs647's Avatar
Wow... +1 for a beautiful car. Where did you get the Ralliart mudflaps?
Old Feb 4, 2009 | 09:28 AM
Evo_Mic's Avatar
power wise? If so it was 400 bhp & 440 l/b at the flywheel before I put the 3" exhust on the car.
Cheers for the comments guys
Old Feb 4, 2009 | 10:38 AM
S6devil's Avatar
must you tease us with the things we cant get here ???? You dont see us posting pics of the Statue of Liberty, do ya ?
Old Feb 4, 2009 | 10:40 AM
DocCola's Avatar
nice VI!!!!
