92' Evo 1 GSR Rally-X
Old Feb 9, 2009 | 03:12 AM
deviantek's Avatar
Recently painted Aspen White:
Action Shots (older):
Snapped a few shots at the local parking garage (terrible lighting)
A little snip from a dirty rally-x:
Modifications:
Lancer Evolution GSR CD-9A (October, 1992)
Engine (evo 3)
* Rebuild by ALEX (3,875 miles ago)
- Mitsubishi piston rings, thrust bearings, main bearings, front & rear main seal
- Mitsubishi Evo new turbo
- Power Enterprise 1.5mm metal head gasket
- Power Enterprise timing belt and balance belt
- Rally Art engine mounts
* NGK racing spark plugs
* NGK racing spark cables
Transmission
* Rebuild by ALEX (4,500 miles ago)
- Mitsubishi ALL new bearings, synchro-mesh rings
Suspension
* Replace stabilizer and lower arms from CD9A (Evo 1) to CE9A (Evo 2, 3)
* KYB Rally / Gravel springs
- Front: 4.2kg/mm
- Rear: 3.5kg/mm
* KYB Gravel shock
- Front: Rally Special
- Rear: Rally Special
* Rally Art suspension upper mount bushings
* Rally Art front tower bar
* Rally Art rear tower bar
* Cusco Type 2 lower arm bar
* Jspeed (Car Station Marche) fender braces
* Cusco Zero-2E coilovers w/ Cusco Econ (currently uninstalled)
Differential Gear
* LSD with ALEX custom setting
- Front: Cusco LSD RS 1 way 4,000Km (2,500mile) ago
- Rear: Cusco LSD MZ 1 way 3,500Km (2,188mile) ago
* Evo RS front LSD conversion parts
* Evo RS rear LSD conversion parts
Exhaust system & Air cleaner
* Fujitsubo RM-01A Exhaust system
* Fujitsubo racing down pipe
* After market stiff muffler bushings
* M's air cleaner
Clutch
* Cusco Hyper clutch cover
* Cusco Hyper light weight metal clutch disc
* OS Giken light weight fly wheel
* Knight Sports stainless steel mesh clutch hose
* Mitsubishi new clutch master cylinder
* ALEX stiff clutch pedal bracket
Brakes
* Brake pad
- Front: Delphi Lockheed ZR (for racing track)
- Rear: Delphi Lockheed MT (for Rally and Auto-X)
* Brake calipers Rebuild by ALEX 3,000Km (1,875mile) ago
* ALEX brake piston position helper springs (inside of the front brake calipers)
* APP stainless steel mesh brake hoses
* Cusco brake master cylinder stopper
* Mitsubishi new hubs and knuckles
For Rally
* SAFTY21 (Cusco) 14 points CDS roll cage with
SAFTY21 roll cage sleeve (order made)
* SAFTY21 (Cusco) A and B pillar reinforcement plates
* Carrosser (Cusco) front skid plate
* Carrosser (Cusco) gas tank guard
* Carrosser (Cusco) differential gear box guard
* Carrosser (Cusco) Rally mud flaps
* ARP Extended Wheel Studs
Interior
* Driver side
- SPARCO Corsa 2000 model black seat
- LaStrada Rally Super Low position seat rail
- Sabelt racing seat belt (3 inch / including shoulder pads)
- Carrosser (Cusco) Rally foot rest
- ALEX custom eye ball mounts for 4 points seat belts
* Passenger side
- SPARCO Evo2 2004 model black seat
- Sabelt racing seat belt (2 inch / including shoulder pads)
* Sparco Safari Suede 350mm Steering Wheel
* Rally Art manual shifter bushing
* RAZO WRC style shift knob
* Rigid Alpha break and clutch pedal covers
* AC, CD, speakers, radio units and floor cover are removed
* Blitz turbo timer
Others
* Mine's race tune ECU
* YOKOHAMA ADVAN A035 (195/65 R15) tires
* 5Zigen FN01R-C 17x8 wheels with Falken Azenis RT615 225/45R17 tires
* Mitsubishi Lancer Evolution 3 stock OZ white wheels
* Mitsubishi Lancer Evo 15" rims on Gravel Rally Tires (Rims are Mint, tires have some use)
* Power Enterprise MAG Power 2 oil filter
* Mitsubishi cam shaft position sensor 600Km (375mile) ago
* Red Line engine, transmission, T-case and LSD oil (10w40, WD-90, & Heavy Shock)
* Evo MR Bypass Valve
* ASI 50mm Aluminum Race Radiator + ASI Hoses
* SuperPro Rear Control arm, Trailing Arm & Rear Sway Bushes
* Rear Control arms reinforcement plated (by Speedware)
* Sparco Hood Pins
* Cusco Cooling Plate
Older PICTURES in this thread (thread had too many pics, decided I start clean):
https://www.evolutionm.net/forums/sh...d.php?t=337052
Old Feb 9, 2009 | 06:39 AM
Jakeg97's Avatar
very nice
Old Feb 9, 2009 | 06:48 AM
Bimmubishi's Avatar
much better than the flat black.
Old Feb 9, 2009 | 08:04 AM
loofee's Avatar
just simply *****ing!!! C
Old Feb 9, 2009 | 09:53 AM
Its a 7's Avatar
Looks awesome! My only suggestion would be to paint the intercooler pipe behind the grill black. I want one of those 4WD full time stickers thats on your back window.
Old Feb 9, 2009 | 09:55 AM
crazy evo's Avatar
nice
Old Feb 9, 2009 | 10:07 AM
K.Bullet's Avatar
That ride is so sick!!!
Old Feb 9, 2009 | 11:13 AM
DxbIX's Avatar
very nice, and a true classic, good to see its been used as intended aswell..... thumbs up!
Old Feb 9, 2009 | 11:44 AM
canyonkid's Avatar
Omg thats sick
Old Feb 9, 2009 | 03:12 PM
Timmay81's Avatar
thats pretty bad ***
Old Feb 9, 2009 | 03:15 PM
itsme4g63's Avatar
thats crazy awesome! that thing scoots!
Old Feb 9, 2009 | 03:21 PM
Evolution IVGSR's Avatar
Awesome man your one of the very Few Evo 1's Good to see you use it for what it was built for too The white looks a lot cleaner than the old color too very nice choice
Old Feb 9, 2009 | 11:32 PM
codgi's Avatar
Still a nice machine...brings back memories .
Old Feb 10, 2009 | 12:36 AM
Evil9's Avatar
damn dude i love rally evos, nice parts list BTw
Old Feb 23, 2009 | 06:51 PM
evo8jedi's Avatar
thats freakin hawt!!!
here's my old evo 1 at Gymkhana ( auto-x)
http://www.youtube.com/watch?v=ErD7glpgixU
