trying to debadge need some help
Old Sep 29, 2003 | 11:13 AM
redphage's Avatar
Goo Gone is citrus based, not as damaging as gasoline or another straight solvent...Just looking out for a brother and his thin thin layer of crappy Mitsu clear coat.
Old Sep 29, 2003 | 11:32 AM
webguy330i's Avatar
Actually it's got citrus oil in it but it's still a petroleum-based solvent. I know what you're saying, it's just that gasoline isn't all that tough against things it can't readily dissolve anyhow (it evaporates too quickly to do much). It's not like we're rubbing sulfuric acid all over the car or something.
Old Sep 29, 2003 | 11:34 AM
webguy330i's Avatar
Oh one more thing you could try is lighter fluid. Works wonders on just about anything too, including your zippo (which may be clearcoated as well!).
Old Sep 29, 2003 | 11:51 AM
leif's Avatar
use carnuba wax. put it on a cloth and go nuts on the glue. carnuba is really good for taking stuff off paint if u dont want to clay bar and start all over with the detailing process in that section.
Old Sep 29, 2003 | 12:06 PM
webguy330i's Avatar
leif, I would think that would cause some swirling once the wax is tired/dried up.
Old Oct 2, 2003 | 11:04 AM
leif's Avatar
naw....it wax, so it'll keep it nice and shiney, i don't see how that would cause swirls. just make sure u use a microfiber cloth or something that you normally apply wax with. when you're done just wax over the entire trunk area so its all even.
Old Oct 2, 2003 | 07:43 PM
leaveit2bevo1's Avatar
In Timeout
Its easier to heat them up and use floss to get them off. youll kill the badges trying to peal them off just use floss. I used 3m adheasive remover and it worked alright.
Old Oct 2, 2003 | 07:48 PM
ozlancer0z's Avatar
although i think it would be perfect for this .. goo gone does NOT taste good.
Old Oct 2, 2003 | 08:00 PM
cerfur's Avatar
they way i have always done it pesonaly is to get some good strong fishing line and cut the badge of leving the gray adheseve behind next heat the crap out of it wiith the girlfreinds hair dryer then peel with your fingers what ever remains hit it with the goo gone i just did my girlfreinds spec v and i didnt even need the goo gone barley at leat use it on 2 dime sized spots
Old Oct 2, 2003 | 08:17 PM
Quickshift's Avatar
Hair Dryer first and then Goobgone to remove any excess sticky goo always worked for me , but wax afterwards and u will be fine.
Old Oct 2, 2003 | 08:25 PM
bakjho's Avatar
wish i read this post earlier. i'll have to get some of that goo gone. guess i'm just gonna drive around with lancer evolution slightly outlined on my trunk for a day..
Old Oct 2, 2003 | 09:24 PM
Foote's Avatar
got all the stuff off an put the badge on the pic has a lot of glare
Junkyardspecial
Mar 15, 2017 08:23 AM
SnailSpeed
Oct 20, 2016 09:34 PM
aka03
34
Apr 18, 2011 12:16 AM
phillman332
17
Jan 22, 2006 04:18 PM
wduvall
Mid-Atlantic Region
11
Aug 4, 2005 10:15 PM
