Radar Detector\Laser Jammer Thread
Old May 13, 2009 | 06:04 AM
EVOLV3D's Avatar
Im looking at installing a valentine 1 and laser interceptor in the very near future and want to see other peoples set-ups for "preventative measures". Such as locations and anything custom installed.
Old May 13, 2009 | 09:46 AM
EVOLV3D's Avatar
anyone?
Old May 13, 2009 | 10:14 AM
YogSaahoth's Avatar
Veteran: Army
I have mine hard wired into the brown line coming off the cigarette lighter..its a prettly simple, but time consuming install. the v1 comes with necessary hardware (a little phone jack looking thing with a short red and black wires) . just remove the whole center console, splice into the brown wire with short red wire, ground the black and run the cable that connects to the unit to where you want it. i ran mine from the center console over through the steering column then up the a pillar and over toward the center where i have the unit suctioned right next to the rearview mirror...i can post some pics if you want. Valentine 1 is the best btw!!
Old May 13, 2009 | 10:20 AM
TSiAWD666's Avatar
Yeesh, why go through the hassle of opening the console when you can just wire into the fusebox so easily accessible at the bottom left of the dash?
Old May 13, 2009 | 10:25 AM
ultm8mind's Avatar
Veteran: Army
What jammers have you heard about and what do you plan on using? I have the Bel GX65, not a Valentine, but I'm on an Army budget and it works for me....lemme know about the jammers bro.
Old May 13, 2009 | 10:29 AM
KiiD2X's Avatar
+1 I want to know more about these "Jammers" too.
Old May 13, 2009 | 04:25 PM
YogSaahoth's Avatar
Veteran: Army
ha if had only known...this was one of the first things i did with the car so i was unfamiliar with the electrical layout. i read a how to that used the cig lighter so i followed suit. it worked out and really wasnt too much of a hassle
Old May 13, 2009 | 05:43 PM
mineisnine's Avatar
Ok check it out, here is a sweet setup.....Dont ask me how it is done, the previous owner did the install.
The clock has been removed and in its place is this mini display for the V1, same screen as the actual radar just smaller. The actual radar sits in the rear window. The volume/pwr control sits in the ashtray. When parked i have a hat that covers the radar so no one is the wiser.
The V1 is the best radar by far!!!! The luxury of this radar is the directional arrows which helps ALOT!! The amount of range/time this radar gives is the best I have ever seen.
Attached Thumbnails Radar Detector\Laser Jammer Thread-v11.jpg   Radar Detector\Laser Jammer Thread-bp-romeoville-il-004.jpg   Radar Detector\Laser Jammer Thread-bp-romeoville-il-001.jpg   Radar Detector\Laser Jammer Thread-image_109.jpg   Radar Detector\Laser Jammer Thread-image_122.jpg
Old May 13, 2009 | 05:50 PM
Harro's Avatar
Oh damn, awesome. Looks like it came right out of the factory.
Old May 13, 2009 | 08:02 PM
EVOLV3D's Avatar
As far as jammers go there are a few out there for laser, not radar. Look up Blinder m25, Laser Interceptor, which is the best out there.
CtSilver03Evo
For Sale - Miscellaneous Automotive
15
Dec 17, 2009 09:37 AM
Arkow
12
Mar 14, 2008 06:12 AM
thestaton
22
Sep 6, 2007 04:48 AM
NWEvoViii
70
Aug 26, 2007 06:40 PM
RA42925
Sep 1, 2006 08:53 AM
