2.0 build
Old Jun 15, 2009 | 07:35 PM
Wheatley's Avatar
AMS 2.0 build/ weird kelford,FP beehive problem
Some updates.
Over the past few weeks I have been noticing some oil consumption and a little blue smoke. I decided with my "need" to make more power and the fact I was well into the 70k mile range on the stock engine it was time for a little added protection.
On to the good stuff.
I found out my maf was just about to give out on me, good thing I caught #1
This is what I found when I pulled my igniton off, "lake evo"
I had signs of water in the tb and the piping. I can only guess that all the water is from the monsoon we had after pinks and all the large rivers running across the road on the SS.
Just one pic of the leaking valve seals.
Well at least it was still together, some wear but I didn't think it looked abnormal.
Found out why my valve seals were leaking!!
Now onto the new parts.
Other than my missing rear main seal bolts everything came back to me. No biggie they are just 10mm.
Note the block said evo 9, here is what it takes to run a 9 block in an 8
Thanks to Aaron for helping me get this beast on the stand.
Machined balance shaft.
Well, thats all I have until I get the head back.
Old Jun 15, 2009 | 09:11 PM
EvolNinja's Avatar
Nice build. Keep it coming. I think I'm going to go with the 2.0 build too when the time comes.
Old Jun 16, 2009 | 02:26 PM
Wheatley's Avatar
Well I talked to T.H.E today about the head. To me it sounds as though I am very lucky to have taken it apart when I did. In addition to the vavle seals being destroyed he found several other possible issues.
The guides are badly worn and in need of replacement.
Another interesting thing he found and is assuming what led to the valve seal destruction is a possibility of coil bind.
He Did a test and only had a max of 10 thousands of an inch between the coils. Tomorrow Im going to call FP and get the specs on thier beehives to verify I didn't just get a bad batch.
The bottom of the retainers were polished from the contact with the valve seals and noted when replacing the guides he will drop them down 50 thousandths and that should solve the clearance issues in the future.
Im wondering what route I should go with on the spring issue. If the springs are up to spec, is 10 thousandths considered a safe amount of coil clearance at max lift to prevent coil bind in case of an over rev?
I have on occasion ran it to about 8k with the new springs and cams. Is this considered too high or this combo? Kelford 272/fp beehive with stock retainers. evo8
Old Jun 16, 2009 | 10:05 PM
dxbevo9's Avatar
good luck man!! seems nice!
what were your mods before you took the engine apart and how much power were you making?
Old Jun 17, 2009 | 03:32 AM
Wheatley's Avatar
I orig had 400 on a 50 trim and buddy club 272's. I then switched to a 35r, kelfords and a magnus v5. I have no idea how much power I was making.
Old Jun 17, 2009 | 01:51 PM
silver_03_evo's Avatar
where did you get that adapter i was thinking of just blocking it off and running the oil sensor on the oil filter housing like the 9
Old Jun 17, 2009 | 03:30 PM
Wheatley's Avatar
The adapter came from ams.
Old Jun 17, 2009 | 08:00 PM
damn im gonna have to see if i can order one from them
Wheatley
Dec 17, 2015 09:23 PM
Wheatley
For Sale - Part Outs
21
Jul 31, 2013 01:37 PM
Wheatley
22
Jan 27, 2011 09:22 AM
Wheatley
For Sale - Wheels / Tires
10
Nov 7, 2010 11:01 PM
Wheatley
28
Feb 24, 2010 06:22 PM
