Beatrush with aftermarke FMIC and downpipe.
Old Aug 17, 2009 | 02:01 AM
HxllxMan's Avatar
Hi,
Just posting some pictures of the beatrush undertray installed with an aftermarket FMIC and aftermarket turbo kit and downpipe ( AMS )
Might help some people who aren't sure ( like I was) to get one.
First, I hope you know how to "read well" pictures if you don't know Japanese .
Pictures aren't that good, so you have to use your head a bit...
The beautifull piece of metal that I'm hoping will fit... since I heard a lot of peoples saying it won't be possible with turbo kit especially
Panel A under the car, no problem with the FMIC but touch slightly the downpipe. No need to cut anything and the fitment is great ( can almost say perfect ).
Having a turbo kit with a downpipe going lower than stock aftermarket type. The panel B ( blue one ) will not fit unless you do some modification. Panel B is supposed to be over the Panel A, but I installed it under Panel A so it will allow more room for the downpipe.
I did the same thing with the brackets, installed it under the bar to allow more roonm for the downpipe.
Screw everything and voila, the big *** downpipe is in!
Full view of the beatrush
Now I'm wondering if leaving the downpipe touching the panel will not damage anything, is it bad to heat the panel? I'm thinking of painting or using Dei stuff to protect the undertray.
Other downpipe might required to use some washers to allow more room for downpipe if it goes lower, but this show you can use the Beatrush!
Old Aug 17, 2009 | 08:53 AM
NY Evolutionary's Avatar
Thanks for the pics/review! Now I need to find out if it fits with the AMS oil pan!
Old Aug 17, 2009 | 09:42 AM
xmaciek82x's Avatar
Looking good. I recently bought on myself recently.
Also, looking at your pics, you might have that back peace installed incorrectly. Nothing major, but it should actually go under the front piece and not above like you have it.
Old Aug 17, 2009 | 10:14 AM
black95tt's Avatar
He mentioned why he bolted it on that way. It makes sense.
Old Aug 17, 2009 | 12:11 PM
HxllxMan's Avatar
How much lower the oil pan is than the stock. I doubt it will be lower than the downpipe or stock undertray.
I will drill and add more screw, so no more gap between the 2 panels.
Old Aug 17, 2009 | 12:41 PM
slowr_evo's Avatar
hell yeah man looks nice, but hopefully the down pipe wont cause a problem touching the blue piece
Old Aug 17, 2009 | 12:49 PM
HxllxMan's Avatar
I'm more worry about the vibration than the heat. I can still lower the panel by bending and adding washer.
Old Aug 17, 2009 | 12:55 PM
Boost3dxEvO's Avatar
hey thanks so much for the pictures and review.. Do you by any chance have any pictures of all of the brackets that were included with the beatrush undertray? I received one "used" and i don't think i received all of the brackets needed for install.
Old Aug 17, 2009 | 01:09 PM
HxllxMan's Avatar
Sorry I didn't took any pics of it. But if I can remember... you should have at least 5-6 small little bag with mixed screw, washer and nuts.
Old Aug 17, 2009 | 01:20 PM
The AMS Oil Pan is 3/4" deeper, and it hits the stock belly pan where the brake cooling channels are.
Attached Thumbnails Beatrush with aftermarke FMIC and downpipe.-dsc01295.jpg   Beatrush with aftermarke FMIC and downpipe.-dsc01296.jpg
Old Aug 17, 2009 | 01:26 PM
HxllxMan's Avatar
Omg that is low, there is no way the fron panel will fit. Mine touch a little bit where the downpipe start to bend!
Old Aug 21, 2010 | 12:40 AM
fabshopmiami's Avatar
Were can I buy one?
Old Aug 21, 2010 | 07:37 AM
sir-eth's Avatar
I love the Beatrush. Can't wait to get one. Looks like a easy and clean install.
Old Aug 21, 2010 | 11:48 AM
4g63Moon's Avatar
good stuff
Old Aug 22, 2010 | 11:29 AM
dunk186's Avatar
just wondering if anyone has had any luck installing the panel with a vr style cf clip
SpunEvoIX
For Sale - Part Outs
86
Feb 4, 2009 09:35 PM
SpunEvoIX
Dec 15, 2008 07:47 PM
lznk41
Feb 2, 2008 02:06 AM
PANGES
Jan 4, 2008 01:05 PM
