cleaning the fmic
Old Oct 18, 2003 | 06:10 AM
majesty's Avatar
cleaning the fmic
how do you go about cleaning the FMIC? would hosing some water on it work? scrubbing it down? let me know, thx.
Old Oct 18, 2003 | 06:38 AM
Lightsped's Avatar
"Scrubbing it down" can easily bend the fins. I would recommend just spraying water on it. If you have bugs inside the FMIC you might need to GENTLY use a screwdriver or some pliers to get them out. The fins are VERY easy to bend. Use caution!
Old Oct 18, 2003 | 10:38 AM
Grod101's Avatar
some engine brite from gunk will clean it up or some simple green... apply to a cool engine.... let settle and then spray off.....
pretty much how you would clean a condensor on an AC house system... but i wouldn't use the chemicals used for cleaning condensors
Old Oct 18, 2003 | 11:08 AM
psionic98's Avatar
there are chemicals out there that foam up after they are sprayed on to things like that... but like grod said, they are mostly used for a/c condensors... it works really really well, but I dont know if there is a huge difference in the construction of a FMIC compared to a condensor other than the size of tubing/fins
Old Oct 18, 2003 | 01:49 PM
Diesel's Avatar
you need to get yourself a small tipped paintbrush to get them bugs outta there... real PITA, but looks so much better when you don't have bug guts all over your ish...
Old Oct 18, 2003 | 02:02 PM
BTRTURBOCHARGED's Avatar
use a toothbrush and toothpaste for a healthy smile!
Old Oct 18, 2003 | 05:10 PM
Grod101's Avatar
if you use a tooth brush you could bend the fins.... just use a foamy cleaner and this will take the bugs out
Old Oct 18, 2003 | 09:29 PM
majesty's Avatar
sounds good to me, thanks for all the reply guys, i just picked up a tarmac black evo for 29k OTD today...its a great car...
Old Oct 19, 2003 | 10:23 AM
sorry about that, use a left to right motion to clean. not up and down, that will bend them!
1SlowRS
Apr 27, 2016 12:06 AM
choko
Northwest Region
12
Jan 21, 2013 04:26 PM
evovin
Jun 19, 2009 09:27 AM
m2
Jul 30, 2007 08:07 AM
projekt_shocker
12
Dec 17, 2006 10:23 PM
