Headlights
Old Dec 7, 2009 | 09:50 AM
quik-viii's Avatar
Unhappy Headlights
I have a ? I cant find an answer too, tried searching alot of stuff, my rightside headlight is out, i have the stock hid's and i was quoted 622$, what should I do? Should I buy a aftermarket hid kit? Or any ideas if its something other than the ballast? (I have already replaced the bulbs left is beautiful and the passenger still didnt work) The old bulbs werent even bad, my headlight did start to turn pink and flicker a little bit, so any ideas for a cheap solution would be a great help thanks!
Old Dec 7, 2009 | 09:53 AM
Genesis8's Avatar
It might be your ballast. Buy a used one. Got mine for $50.
Old Dec 7, 2009 | 09:57 AM
quik-viii's Avatar
where did you get it at???
Old Dec 7, 2009 | 09:59 AM
Genesis8's Avatar
I bought it used off a member on here. You just gotta search.
Old Dec 7, 2009 | 01:50 PM
RockmanX's Avatar
yup just have to search there was a guy selling one evo 9 ballist for something like 200 i think i forget
Old Dec 7, 2009 | 02:58 PM
evodave's Avatar
From: driving the 10 second beast in ohio or running lightmods.net
i have a ballast and bulb i can sell ya
Old Dec 7, 2009 | 03:10 PM
Jp7's Avatar
Jp7
Many aftermarket HID sites sell replacement ballasts for D2S.
Old Dec 7, 2009 | 04:51 PM
streetracerkam's Avatar
I have ballast and bulb I can sell.
Shoot me a PM with an offer.
Im not looking for much
Old Dec 7, 2009 | 05:13 PM
yahu's Avatar
OP - I'd figure out your problem before continuing to spend money that might not fix the problem. Check your good ballast on the bad side's wiring harness. Check your bad ballast on your good side's wiring harness. Same with bulbs, but it sounds like you've already done that.
As others have said, you can buy specific parts like just the ballasts from individuals on here, Vendors, online, etc. Good luck!
joonvang
Jun 8, 2016 08:10 AM
TxFAkuma
Sep 30, 2015 08:55 AM
Mistaken
Sep 4, 2013 02:35 PM
warner
Aug 17, 2013 04:11 PM
dbowdt
Lancer Troubleshooting
Mar 27, 2012 07:03 AM
