polished hood
Old Jul 1, 2011 | 03:26 PM
  #316
Arkitek's Avatar
cool idea! I like it
Old Jul 1, 2011 | 03:59 PM
  #317
Dynhamik's Avatar
Dope...
Old Jul 1, 2011 | 06:52 PM
  #318
DEVIL EVO IX's Avatar
I sorta like it now you can go find a girl and say come look at my car I painted it to look like you. :P
~Sean
Old Jul 1, 2011 | 10:14 PM
  #319
TheBoz's Avatar
That is cool as hell. If you had an aluminum roof you could polish that also. I love it.
Old Jul 1, 2011 | 10:45 PM
  #320
zenki-s13's Avatar
looks awesome man, different
Old Jul 2, 2011 | 12:02 PM
  #321
arnoldp's Avatar
I think it looks great
Old Jul 2, 2011 | 12:38 PM
  #322
afgtrackstar's Avatar
if the whole car was polished that would be sick IMO>
Old Jul 3, 2011 | 07:13 AM
  #323
Evolento's Avatar
hmm lets see if I can do a quick write up.
You will need to buy aircraft stripper from your local discount auto parts. It's in a decent size tin container. It's a gel like substance, and it costs around $17.
I laid the hood on top of some plastic chairs to elevate it from the floor, and started spreading the gel with a paint brush all over the top of the hood.
Let it sit for a few hours so it can eat at the paint, it wont damage the aluminum.
I used a pressure washer to remove the excess paint that was dangling on the hood so I don't scratch the hood...do not use a razor......you can use a plastic spatula of the sort. Something that is semi firm but flexible.
^that process will need to be repeated a few times until everything is removed.
After the paint and primer is off, I started WET sanding the imperfections and all. Started with 600, then 800, 1000, 1500, then 2000. Wet sand in an up and down motion, not circular. I noticed it worked better that way.
Then polish it up, I forgot the exact compounds used because my friends was doing most of the polishing with their brands etc, but I'm pretty sure most will work. Buffers definitely help to finish the polishing process a lot quicker lol.
Old Jul 3, 2011 | 07:19 AM
  #324
Evolento's Avatar
oh and thanks for all the compliments and suggestions... Still considering in buying an extra set of fenders to do it too lol
Old Jul 3, 2011 | 09:06 AM
  #325
1UpMoto's Avatar
I like it, It goes great with your wheels. I cant imagine this looking good on any other evo tho.
***edit**** leave the fenders alone lol.
Old Jul 3, 2011 | 09:22 AM
  #326
2slow4now's Avatar
Thats a different idea. I wouldn't do the fenders. The only thing I would worry about is corrosion on the bare aluminum. I was thinking something like the wheel coatings on stock wheels but they even get corrosion. Weekly polishing and bug removal. LOL
Old Jul 3, 2011 | 09:33 AM
  #327
noob12's Avatar
Nice. First I've seen.
How hot does it get if sitting in direct sunlight for a while? Probably can fry some eggs on it huh?
Old Jul 3, 2011 | 09:44 PM
  #328
Evolento's Avatar
If I do it, it wouldn't be on my stock yellow ones
good call, not sure. This is an extra hood and I'm garaged. It hasn't happened to my friends miata that has a polished hood for over a year and he is outside?
never tried it lol.
Old Jul 6, 2011 | 12:32 AM
  #329
IbeBOOSTIN's Avatar
This hood looks very nice!!
Big props on it
If you ever wanna sale it I'll buy it off you
Old Jul 6, 2011 | 12:43 AM
  #330
IbeBOOSTIN's Avatar
Also to answer some questions bout corrosion on polished aluminum
Try using clear.. A nice coat or two of clear will help protect it n give that
Extra lil bling factor I've personally done this on lca valve cover for honda/integra
N no problems here
Do research before you try n knock me as well as don't buy cheap ish
