*Unreleased* Rexpeed CF Rear Diffuser
my next question is, this being a full rear diffuser, will this work with the jdm rears?
Where is Rexpeed to chime in on this? I'm really interested but, as I mentioned in my previous post, I don't think it'll work with stock exhaust or my Perrin CBE. If it in fact does work, I'll be all over it as I'd imagine others would too.
while i agree with you, i also disagree. how are people going to keep said companies in business when they charge absurd amounts for parts? i know its a costly process for r&d, etc, but they attract a select circle of customers. like arc for example, yea i have arc parts. but i way overpaid. $500+ for an intake tube? theres where i have the problem.
Hope this kind of helped you out with your decision. Aloha!
From installing this part, I think a OEM type muffler would fit with some trimming of the diffuser. I actually had to trim a bit to fit my slanted muffler. I'll try to borrow a stock exhaust from a friend and see how it lines up.
Is the Perrin muffler the same size as the OEM one and is the angle the same. If so I'll try to line up a OEM muffler to check the clearance.
Sure. No, it will not fit a JDM bumper.
Better?
It's blatantly obvious and shouldn't need explanation, particularly to the owners of JDM bumpers. JDM bumpers are different size and shape than the USDM bumpers. This diffuser was made to fit USDM bumpers, ergo, it will not fit JDM bumpers. Mmmmmkay??
Better?
Thanks for checking!
I own the APR piece and it is identical, if not better quality. The only difference I noticed is that the front lip where the support rods bolt in are flat on the RexSpeed. The APR has a rolled edge to stop the "parachuting" effect
