Darkn3s SEX Build ||pics||
long story.. well i have a hard upper radiator pipe and i had the ground wire from cam sensor resting on it somehow and i guess overtime it eventually got hot enough to melt the wire all the way down into the engine harness melting a good 6 wires together causing them to touch and cause all sorts of ugly.. anywho two of those wires were from my 3rd injector.. and some how the injector was triggered to open spray non stop as soon as the ignition was rolled.. so basically 3rd cylinder was flooded in fuel and hydrolocked the motor with fuel.. pictures of the bearings from above are from cylinder 3
