Weekend Track - Daily Driven Evo VI TME
Old Feb 13, 2011 | 01:38 PM
TougeGod7's Avatar
Originally Posted by R/TErnie
-Girodiscs 2pc front and 1pc rear rotors I have this setup. I recommend the Raybesto's ST43 pads F&R
-Enkei rpf1 or nt03 17x9.5 rims Good choices as well
-Ams intanke mani (is the boomba throttle really "helpful"?) (check out the Magnus v5, cheaper, and makes identical power to the AMS with a little more power after 6k. I use the stock tb for better throttle control. Check out MIL.SPEC throttle shaft seals.... they also offer a 65mm bored stock throttle body.)
-GSC S2 cams & ported head (Good cams, hit up English Racing for the GSC's and the head)-GSC XR-1.67 2.2L stroker kit (I'm building a 2.2L too... this is a nice kit for sure)
-Quaife front, center and rear diff (does someone know how all of them work together? ) Jon@TRE www.teamrip.com He can do your entire drivetrain.... I recommend getting a hold of him. You'll love his stuff Knows his stuff!
-Exedy Stage 5 clutch (triple disc) Check out the QuarterMaster 8 leg hub drive Twin... it will shift better than the Exedy. MAPerformance sells the QM. Hit up Adam.
-Carbon fiber trunk and roof be wary of crappy carbon parts. Make sure they use Epoxy resin and the part is made of carbon and not carbon and glass.
-Cusco roll cage (I'd look around for other alternatives. Maybe even a weld in cage)
-Haltech o2 system + digital dash
-BBK-B or FP RED / BBK Full or FP Green turbocharger (have you seen the HKS7460 yet?) I think its right up your alley
-SERIOUS weight reduction (always good.)
great pictures. thank you for sharing!
very good advice right here
Old Feb 13, 2011 | 02:48 PM
way2qik's Avatar
Great car and great pictures. Thanks for sharing.
