Official "STANCED" Evo Thread
Old Jun 27, 2011 | 09:45 AM
  #316
Alchem1st's Avatar
How do you go about pulling the fender like that without destroying the paint? I need to do that to my car to fit 225's (The E4 conversion is rubbing a little with 215's )
Old Jun 27, 2011 | 10:07 AM
  #317
nogoEVO's Avatar
take a heat gun to your fenders prior to rolling it. it softens the metal and paint so it wont crack. im going to do this today actually. got to find the right amount of heat, you dont want to heat it too much because the paint will bubble...not enough and it will crack.
Old Jun 27, 2011 | 10:19 AM
  #318
Alchem1st's Avatar
How do you pull it though? Just keep rolling till it flares out?
Old Jun 27, 2011 | 10:21 AM
  #319
EvoJoeRacing's Avatar
Originally Posted by EriCS
I recently just read something in I think the "Aggressive Wheel Fitment" thread that these Japanese time attack cars are limited to a selection of tires. In other words there aren't too many options as far as wider and diverse tires available. I also will agree with others that a stretched tire does absolutely nothing but impede the handling of any car. Slamming and stretching ties on an evo or any other performance vehicle beyond the funtionality of its suspension and tires is just plain stupid and pointless. To each his own but in that case by the civic on the page before or some other car that is not produced with performance in mind in the first place and save yourself some money...
Thats not 100% true. Stretching a tire does have some performance functionality behind it. Now when i reference stretching im talking about a 275 on a 10.5 rim. Not a 225 on a 10". Having a stretch to a tire gives the tire and steering more of a crisp response. Your turnin feedback is quicker. Running meaty tires that bulge over the rim leads to a sloppy tire and slower response. So to a certain extent, stretching tires does have some performance advantages but its within reason.
Old Jun 27, 2011 | 10:24 AM
  #320
Alchem1st's Avatar
^He's right, I'm running 215's on an 8in wide wheel and it's nice and tight. Not as much sidewall flex. Would like to get more rubber on the ground though.
Old Jun 27, 2011 | 10:29 AM
  #321
nogoEVO's Avatar
i think you just have to pull the roller towards you while your rolling it.
Old Jun 27, 2011 | 12:43 PM
  #322
dookiedang's Avatar
Originally Posted by e v o
Here is mine:
18x10.5 +7 all around
nice job!
what size tires are you running?
plus are those varrstoen wheels or real volks?
and any rubbing in the front/rear at all?
looks nice.
oh yea what suspension and camber? haha i so want this damn setup. let us all know! thanks
Old Jun 27, 2011 | 12:50 PM
  #323
e v o's Avatar
Originally Posted by dookiedang
nice job!
looks nice.
tire size : 235/40/18
wheels: varrstoens
Suspension : bc coilovers
Camber: -1 (r) , -1.5 (f)
Rubbing : yes! only in the front and only on big bumps,.... if i run another -5 degrees of camber that should go away. Front fenders are stock with just a roll.
rear fenders where professionally cut, molded and and rewelded by a body shop , about 2-3in. wider then stock
I am in the process of lowering the car more , the pics will be up soon
Old Jun 27, 2011 | 12:53 PM
  #324
nogoEVO's Avatar
wheels: varrstoens
yo i got the same wheels sitting at home but with a +15 offset. will i be able to pull off the same tire size if i just roll the fenders?
  #325
Alchem1st's Avatar
wheels: varrstoens
Sick!
Old Jun 28, 2011 | 10:17 AM
  #326
Josh@MooreAutomotive's Avatar
Here is my New Setup on the Standard Suspension R3's.
Tire-BFgoodrich KDW2
Tire Size-245-40ZR17
Old Jun 28, 2011 | 10:57 AM
  #327
rotary_bunta's Avatar
some very pretty cars in this thread.
Old Jun 28, 2011 | 11:58 AM
  #328
BrendanS's Avatar
Should be able to if you roll flat and maybe a tiny pull. Try running it with more camber, I'd try 3.5 up front and 2.5 in the rear
Old Jun 28, 2011 | 06:50 PM
  #329
lilal's Avatar
wow i havent been on for a week , n there is a lot more beautiful evo
Old Jun 28, 2011 | 07:29 PM
  #330
Paulito's Avatar
Rolling is not that technical and no the heat doesnt soften the metal.
A true pulled fender is hammered and dolleyed to shape and involves some filler and a respray. I did it on my old vw years ago and pulled the rear about 2 inches and the front about 1. I ended up adding metal to get the proper shape.
With a roller all you can do is 2 things; roll the right way and keep the shape of the quarter or you can flare it which distorts the body line. Its all about the angle of the wheel on the roller.
As far has heat goes its not a science and to bubble the paint would take alot of heat... I heat till its hot to the touch and go from there and continue to reheat and gradually roll decreasing the angle of the wheel slightly.
heres a shot of my bodywork before i got rid of the car for my evo... which is on fat tires and used accordingly with rolled quarters to fit my 255s but to each there own, i enjoy looking at "stanced" cars but not owning one anymore.
http://www.flickr.com/photos/23088229@N02/2517330968/http://www.flickr.com/photos/23088229@N02/2517330968/ by http://www.flickr.com/people/23088229@N02/, on Flickr
