MY Evo After The Build
Old Jun 20, 2011 | 01:57 PM
Dragking2189's Avatar
Hello guys , during the last 4 months I've been building my Evo Ix . I ca start off by saying it has not been a walk in the park since I had a million other things going on at the same time . Finally is done and hoping to get it tune ASAP. First I need to break her in . As of now , the car has 45 miles on the new motor. I posted this just to share with you guys and get some opinions. sorry for the poor quality pics , I lost my camara with all the build pics in it
I still have to finish cleaning the engine bay and hiding all the wires . I also need to install the coilovers and other misc things . this is what it looks like so far . Feel free to add your opinion even though is not pleseant .
Here is a list of th mods, I'm sure I'm forgetting some things , I will try to add the most important parts.
Engine/ Drivetrain
Built 2.0L 10:1 compression /Je pistons/Manley TT rods /upgrade pins/Acl bearing.
Stock head /Cosworth m3's/Supertech valves/L19 studs
Hta3586r Custom turbo kit
Exedy triple disc
Rebuilt trans with Evo8 3rd and 4th gear .
shifter bushings
custom intercooler pipes
4" mishimoto intercooler
Buschur intake manifold
65mm throttle body
3" full exhaust
mishimoto thermostat
Gates belts
Fluidampr
balance shaft elimination kit
Tial bov and Wastegate
Spartech ignition
Fuel
Perrin fuel rail
Aeromotive Fpr -8 feed -6 retun fuel lines
Fic 1600's
stock ecu on speed density
Here a vid I took at my buddy's house when we fist started it. Lmao at the strap on the intercooler , the brackets were not welded at that time
http://youtu.be/tNqX9LEad0c
Old Jun 20, 2011 | 02:13 PM
djslik408's Avatar
what a clean engine bay!! Very nice.
Old Jun 20, 2011 | 02:27 PM
thanks dude, I still need to hide some wires and remove the throttle cable and run it through the back . I still have a maf in there untill I break her in then switch to a 4" intake.
Old Jun 20, 2011 | 02:44 PM
s.e.a.n.'s Avatar
Very nice man!
I'm doing a 10:1 build on my car as we speak.
Can't wait to see what it puts down.
Old Jun 20, 2011 | 03:12 PM
vipers's Avatar
very nice!!!!
Old Jun 20, 2011 | 03:16 PM
Originally Posted by s.e.a.n.
Very nice man!
What going on Sean , I can't wait to get it tuned. I don't even know how much power it will make. Whatever it makes I will be happy with it. I saw your car sitting at cwills shop good luck with everything hope to see it runing soon.
Old Jun 20, 2011 | 03:29 PM
rhd-jon's Avatar
thing sounds beefy
Old Jun 20, 2011 | 07:14 PM
Evoleader88's Avatar
What radiator is that?
Old Jun 20, 2011 | 07:24 PM
02BLUR's Avatar
awesome
Old Jun 20, 2011 | 07:28 PM
Ebay radiator, I posted a link below to the fan I'm using . the fancy fittings do not come with the radiator, I had to weld the fitting on the radiator and the thermostat housing to be able to use that line you see there. I've been using this Radiator/ mishimoto thermostat for a while and never had a problem specially on the 95 deg we get here in Miami.
http://www.extremepsi.com/store/prod...cat=492&page=1
Old Jun 20, 2011 | 07:57 PM
do u have the link for the radiator?
Old Jun 20, 2011 | 08:14 PM
This one works , maybe you have to modify the bottom outlet by moving it to the center but I'm sure this one will work .
http://cgi.ebay.com/ebaymotors/CIVIC...#ht_4207wt_948
Old Jun 21, 2011 | 01:14 PM
can someone recommend me a good looking strut bar ?
Old Jun 21, 2011 | 01:23 PM
06MREvo's Avatar
If you can find it, a DC Sports Titanium strut bar... I have the front & rear on my car and both together are under 5 lbs...I got mine from Lancershop the end of last year...
Old Jun 21, 2011 | 03:39 PM
Thanks man just ,just ordered one from Them these bad boys are expensive
