paint coming of from the brake calipers?
Old Oct 27, 2011 | 07:58 PM
IX_MR's Avatar
it looks like the paint or the film is coming of the brake caliper.. how can i prevent this from happening or how can i repaint them? thanks
Old Oct 27, 2011 | 08:00 PM
volkevo9's Avatar
brakes
have them powder coated
Old Oct 27, 2011 | 08:17 PM
sujinX's Avatar
cant really prevent. but u can get them redone.
Old Oct 27, 2011 | 08:29 PM
awdturbo8's Avatar
Mitsu dealership replaced all 4 of my calipers for free. I got lucky.
Old Oct 27, 2011 | 08:56 PM
blknblubkrdude's Avatar
They all peel and fade eventually...
You can clean and scuff the surface, then spray a coating of engine enamel clearcoat. It will last a while, but it's still nothing like powdercoating.
Old Oct 27, 2011 | 09:13 PM
SaulHudson's Avatar
Are all 4 calipers peeling? If so, there is a very high chance that the surface of them was not prepped right. Brake paint does peel and chip eventually, sure, but you have a ix it shouldn't be peeling already, at least on all 4. If only one was peeling then its pretty likely a rock chipped it and it started pulling off but all 4 is unacceptable and should be handled by MMC.
Old Oct 27, 2011 | 09:26 PM
Tevo9K's Avatar
I have a IX and all 4 of my calipers are peeling already!!
since there are layers peeling already so we sand it so the paint will be even or will it even matter since we'll be "clear" coating it??
Old Oct 27, 2011 | 10:23 PM
jdm747's Avatar
It's a simple fix that doesn't cost much or take lots of time...
1. Unbolt the calipers from the disc (you can leave them attached to the lines or remove them completely - your call), clean any grease/grime off them and then sand them back so that all of the existing clear coat has been removed. Once done, give them a clean down with some prepsol or something similar to ensure a nice clean surface for the new paint.
2. Get hold of some high temp engine enamel/brake caliper paint in your desired colour (dunno if you guys have VHT over there but that's what I and many others have used without an issue). Get some replacement Brembo stickers as well.
3. Tape up anything that you don't want painted and proceed to paint the calipers - just follow the instructions on the can. I did a couple of light coats and then a final heavier coat and it turned out fine.
4. Once paint has cured, apply new Brembo stickers, step back and admire your work!
Unless you're having them professionally sprayed in 2k then I wouldn't worry about clearing them since it'll most probably discolour and begin to crack/flake off again further down the track. The high temp enamel has a nice gloss finish and with a new set of Brembo stickers they look great. Plenty of people have done this without any further fading issues etc...just make sure you sand back and then clean properly before applying the paint.
Old Oct 27, 2011 | 10:27 PM
ReidFletcher's Avatar
I got my evo with faded/peeling calipers. After a day at the track my calipers were brown/purple. Brownbos wooo! If you want them to last get them powdercoated.
Old Oct 28, 2011 | 04:52 AM
JoNaH's Avatar
try going to your dealer, most mitsu dealers replace them since its a known issue, if not, gotta powder coat them. you can paint them but a powder coat is the best and longest lasting finish you can do to them.
Old Oct 28, 2011 | 07:54 AM
Fiyaz's Avatar
this is a common issue for evo : (
Old Oct 30, 2011 | 05:46 PM
donmeca2020's Avatar
bingo on that one !!! my 05 evo 8 brembos all started to fade, i heard mitsu had to replace them and when i took it to them they did, FREE OF CHARGE !!!! try a few dealerships before you decide to spray can or powder coat. if you cant get them done by the dealer then i would go and powder coat them a different color.
jingalalahoe
Sep 9, 2016 12:44 AM
babaz7
Mar 22, 2014 02:59 PM
04Evo851374
Jan 9, 2013 04:56 PM
bandwagon
15
Apr 11, 2007 10:12 AM
RaLLi
Sep 23, 2004 02:42 PM
