wheel spacers on the stock Viii rims?
Old Nov 29, 2011 | 08:48 AM
PatricksEvilEvo's Avatar
My evo sits on Tein lowering springs (dropped 1.5") but the car doesn't have the aggressive stance I would like and I do not really want to buy better rims right now. Has anyone used wheel spacers with the stock 8 rims for a better more aggressive look so the fender isn't hanging out farther than the rims?
Old Nov 29, 2011 | 09:59 AM
CJ2X's Avatar
https://www.evolutionm.net/forums/ev...60-spacen.html
https://www.evolutionm.net/forums/ev...ck-enkies.html
https://www.evolutionm.net/forums/ev...s-request.html
Old Nov 29, 2011 | 10:10 AM
boosted91t's Avatar
I run 20mm's on evo 8's and 9's. Needs minor roll in back with stock tire size, if you want to skip the roll do a 15-18mm.
Old Nov 29, 2011 | 04:50 PM
Well the next set of ZRI's I'm putting on my black stock rims will be an inch smaller and half an inch wider than stock size so I don't think I'll need to roll them at all
Old Dec 1, 2011 | 09:02 PM
breeze17's Avatar
go for it, wheels out makes it look clean n aggressive
Old Dec 2, 2011 | 12:40 PM
limp_noodle's Avatar
I'm running 15mm all around on stock wheels. IMO get some 20mm and it'll look better. I'm looking to buy some 5mm spacers to slip in and bring the wheels out just a little bit more.
Old Dec 2, 2011 | 12:45 PM
STiH8T3R's Avatar
thinking about do this aswell.
Old Dec 2, 2011 | 01:58 PM
Vivid Racing's Avatar
I've seen this on a few Evos and it looks good. Since you're going to a narrower tire in the rear, you can most likely get by with 20mm all around. If it rubs in the rear, rolling the fenders is easy. You won't have to worry about bumper tabs or anything like that.
I like H&R spacers because I've never seen any quality control issues and they include the hubcentric rings. PM me if you need help getting a set. We usually have Evo stuff in stock.
Old Jun 16, 2016 | 09:34 AM
rm4g3d0n's Avatar
Did you guys have to adjust the fender for those of you who installed a 20mm?
Old Jun 16, 2016 | 10:12 AM
Installing a 20mm on a +38 wheel leaves you at +18. You can get away with this up front but the rear will cause serious fender issues if not addressed.
The rear will need a tight fender roll & slight pull
Old Jun 16, 2016 | 11:35 AM
rm4g3d0n's Avatar
I've got stock wheels 17"
Will that be an issue?
Old Jun 16, 2016 | 12:46 PM
I did the layout based on your question
Old Jun 17, 2016 | 12:27 PM
Jonno99's Avatar
Has anyone got a pic of standard rims on 20 mil spacers?
Old Jun 17, 2016 | 01:27 PM
^^^See post no. 2 links
CtSilver03Evo
17
May 29, 2026 11:37 AM
Evo82
Apr 20, 2020 12:52 PM
Sebisdaman
Jan 18, 2018 07:38 PM
Allentotora
Jun 5, 2017 12:20 PM
AntilagtunedMR
May 23, 2017 12:58 PM
